Problems with 16F684
Results 1 to 27 of 27
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Problems with 16F684
    Thank You for help ! Mr.Darrel code can be found there : http://www.picbasic.co.uk/forum/cont...CD-on-any-pins
    Mar 2009
    Colorado
    Sorry, fratello....I thought I could help you but I found out your code is setup for use only with the PM assembler which I can't use with my 64 bit machine. I can only use the MPASM assembler. Maybe someone else can help you test compile this.
    Dec 2008
    Ploiesti, ROMANIA
    Never mind...Thanks anyway for help !
    Regards !
    Jan 2010
    Hi fratello!
    I tried to compile but I got :
    Error UNTEST~.ASM 440: [235] opcode expected insted of 'error'
    Dec 2008
    Ploiesti, ROMANIA
    Strange ...
    I have no errors on compiling...just not work !
    Dec 2008
    Ploiesti, ROMANIA
    With code from post #1, I build this thermo-voltmeter for using in car.
    Note : for "I(nside)" I dont have anymore DS18B20 sensor...
    Jan 2010
    Congratulation, Fratello!
    Good work.
