Thank You for help ! Mr.Darrel code can be found there : http://www.picbasic.co.uk/forum/cont...CD-on-any-pins
Sorry, fratello....I thought I could help you but I found out your code is setup for use only with the PM assembler which I can't use with my 64 bit machine. I can only use the MPASM assembler. Maybe someone else can help you test compile this.
Never mind...Thanks anyway for help !
Regards !
Hi fratello!
I tried to compile but I got :
Error UNTEST~.ASM 440: [235] opcode expected insted of 'error'
Strange...
I have no errors on compiling...just not work !
With code from post #1, I build this thermo-voltmeter for using in car.
Note : for "I(nside)" I dont have anymore DS18B20 sensor...
