return for GOSUB not working
Results 1 to 2 of 2
    Sep 2006
    Default return for GOSUB not working
    Running into a little problem. When My Gosub functions ends, it does not return. Instead it stalls there and Both buttons do not work.. I have RB2 for Select and RB3 for Next (buttons) when it finished the minutes, the LCD freezes and nothing happens... some have a clue??
    '///////////     SetProgrammerTime  ////////////
    SetProgrammerTime:
     pause 400
         while Selection = 0           ' exit when selection becomes 1   Selection is a buton and next1 is another button on the main panel
                lcdout $FE,1,  "Set Time?"
                lcdout $FE,$C0, "Next or Select"
                pause 300
            if NextOption=1 then return    'button NextOption,
        wend
    ThisYear = 2011
    Pause 500
                lcdout $FE,1,  "Set Year"
                lcdout $FE,$C0, dec4 ThisYear
                pause 300
            if NextOption=1 then ThisYear = ThisYear +1    'Button on NextOption (PORTB.3)
        wend
    ThisMonth= 1
    Pause 500
     while Selection = 0           'exit when selection becomes 1   Selection is a buton and next1 is another button on the main panel
                lcdout $FE,1,  "Set Month"
                lcdout $FE,$C0, dec2 ThisMonth
                pause 300
            if NextOption=1 then ThisMonth=ThisMonth +1 : pause 50
                if  ThisMonth > 12 then ThisMonth = 1
        wend
    ThisDay= 1
    Pause 500
                lcdout $FE,1,  "Set Day"
                lcdout $FE,$C0, dec2 ThisDay
                pause 300
            if NextOption=1 then ThisDay=ThisDay +1
                if  ThisDay > 31 then ThisDay = 1
           wend
    ThisHour= 0
    Pause 500
                lcdout $FE,1,  "Set Hour"
                lcdout $FE,$C0, dec2 ThisHour
                pause 300
            if NextOption=1 then ThisHour=ThisHour +1
                if  ThisHour > 59 then ThisHour = 1
        wend
    ThisMin= 0
    Pause 500
                lcdout $FE,1,  "Set Min"
                lcdout $FE,$C0, dec2 ThisMin
                pause 300
            if NextOption=1 then ThisMin=ThisMin +1
                if  ThisMin > 59 then ThisMin = 0
        wend
        Pause 300
    'I2CWRITE SDApin,SCLpin,$D0,$00,[$00,ThisMin,ThisHour,$6,ThisDay,ThisMonth,ThisYear,$00] ' Writes to DS1307
     'Pause 30
    Miami, Florida USA
    Default Re: return for GOSUB not working
    Quote Originally Posted by lerameur View Post
    Hmmm, I don't see anything wrong in your SetProgrammerTime sub-routine . The problem might be in your main code after the line GOSUB SetProgrammerTime. See how far the code runs before it freezes.
    Anonymous
