HI all,
Stumped on a PIC10F222 not running the same after coming out of SLEEP or NAP.
After a reset, the led's cycle as expected..... ONCE!
After that, the only one to toggle is on GPIO2 (Green on pin 4).
You can see the rem'd commands for SLEEP and NAP, when one or the other are used instead of the PAUSE, it only cycles the other 2 leds on the first pass. Since the green led still cycles, one can guess that it is coming out of its nap. but why do I loose 2 of the ports?
I am definitely stumped.
I would love to understand this. Any takers?Code:' 10F222 (SOT23-6) ' -----------u----------- ' O led cath -|G0/A0/PGD G3/MCLR/Vpp|- 10k pull-up ' -|Vss(-) Vdd(+) |- ' R led cath -|G1/A1/PGC G2/T0CKI/O4|- G led cath ' ----------------------- ' define OSC 4 DEFINE OSCCAL_1K 1 ' read OSCCAL data and use OPTION_REG = 000000 ' 1:2, timer off TRISIO = 0 ADCON0 = 0 ' All digital for GPIO<0-3> Delay var byte ; used to adjust the delay time ;**************************************************************************** Main GPIO.0 = 0 'Orange led ON pause 50 GPIO.0 = 1 'Orange led OFF GPIO.2 = 0 ' Green led ON for delay = 0 to 50 GPIO.1 = 0 'Red led ON pause 20 GPIO.1 = 1 'Red led OFF pause 20 next Delay GPIO.2 = 1 'Green led OFF 'pause 1000 'THIS WORKS 'nap 6 'NO WORKIE sleep 1 'NO WORKIE goto Main END
Bo
