Disabling MCLR pin
Results 1 to 4 of 4
    Sep 2006
    Default Disabling MCLR pin
    I am trying to disable the MCLR pin because I am using it to do a LCDOUT on that Pin.
    I am using a PIC16F88.
    I read this thread but it is not helping me out.
    I still get compiling error.. illegal upcode
    'LCD testing program  and Clock viewing
    INCLUDE "modedefs.bas"
     OSCCON = %01110000 '8 Mhz
     Define OSC 8
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    @ DEVICE pic16F88, MCLR_OFF
    '// LCD configuration //
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 7 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 6 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    Default Re: Disabling MCLR pin
    DATA sheets are your friend.
    Please read the chips DATA sheet and make it happy
    MCLR is an input only.
    Sep 2006
    I guess I have to find a way to use the LCd another way then, I need the SDA and SCL pins and the Vref,s pins....
    also how come do I get the illegal upcode ???
    K
