send data between 2 microcontrollers by ir(infrared)
Results 1 to 3 of 3
    Oct 2011
    Unhappy send data between 2 microcontrollers by ir(infrared)
    hi for all ........it's long time ago since i start serch for complete my idea but i failed .....
    i am trying to send data(like numbers 1,2,3,....) between two pic16f628a by ir ,i have tested my idea ...as next
    in trans section i configured pwm to 38khz and i used serout2 command to send data as next
    start:
    serout2 portb.0,813,[23,5,8,9]
    goto start
    in recieve section
    i used serin2 and i connect lcd to display the recieved data
    x var byte
    y var byte[4]
    pause 300
    lcdout $fe,1
    start:
    serin2 portb.0,813,300,timeout,[wait(23),str y\3]
    lcdout dec y[0],dec y[1],dec y[2]
    goto start
    for test i connect trans pin to recieve pin directly and i have recieved instead of numbers 3,8,9 ...numbers 224,273,223
    can any one help me ....please........please
    Nov 2006
    Murrieta, CA
    Default Re: send data between 2 microcontrollers by ir(infrared)
    What values are you receiving without declaring them as "DEC" ?
    Bruce has many examples on his site, here is one you might find useful:
    http://www.rentron.com/Infrared_Communication.htm
    and his site index:
    http://www.rentron.com/PicBasic/Rentron.htm
    you can spend (invest ?) lots of time in here.
