how to remap interrupt vector - pic18f4550
Results 1 to 13 of 13
    Default Re: Recieving data
    OK, I think I follow your sequence. Sounds like your using Basic serout or HWserout ??
    I use TXint to send from either ram(array) or flash(1 of several tables at the end of flash mem).
    I will put together the easy change to PB18....lib for arrayread and send you. You (and me too) can be confident since Darrel checked it out.
    Don
    Sep 2005
    Campbell, CA
    I'm using HWserout, but I don't think I could do much better using TXint. It isn't the sending time that is the problem, it is the large amount of processing I have to do with the packets.
    SNMP requires that I do lexicographical sorts (1.2.1.3.1.1.1.4.2.1 is before 1.2.1.3.1.1.1.4.2.1.1 and 1.2.1.3.1.1.1.4.2.1 is after 1.2.1.3.1.1.1.3.9.9.9.9.9.9.9)
    Even if you get sent a string that does not match one that you have (internally) in your list, you have to pick the first item in your list that (lexicographically) comes after the received string,
    then grab the appropriate data, perform encryption on certain bytes (3 different types, depending on the data), re-assemble the variable-length packets, calculate the LRCs, and send.
    And some of the data is a (calculated) number 40 bits long.
    Charles Linquist
    alot to ask of a PIC !
    Sep 2005
    Campbell, CA
    It is doing a lot of data collection at the same time. That is why I'm running my '8723 at 40MHz and it is full of code.
    Charles Linquist
