OWIN - OWOUT problem
Results 1 to 2 of 2
    Default OWIN - OWOUT problem
    I have a problem trying to use other port pins along with OWIN and OWOUT
    When I try to make a port pin high, (on the same port as OWIN and OWOUT), the pin only remains on for about 20 US, which is probably about the time to complete the loop (using the attached program).
    I am not very familar with OWIN and OWOUT . . . Does the command change all the pins back and forth from input to output, etc on that particular port? The SERIN2 command works fine, using a pin on the same port. When I change to another port
    (PORTB in this case), everything is fine, the output remains on. I am using a simple test in the attached program, eventually I will be turning the output on and off depending on temperature.
    I tried using the LAT command on the port pin, thinking it might be a read - modify - write problem, and get a "bad data type" error trying to compile.
    The program is a modified version of one of Bruce's for the DS18B20. The program works just fine. I'm using a 16f876A running at 4 MHz.
    I have commented the problem areas surrounded by a !!!!!!!!!!!!!!!! boundary
    '*  Name    : DSB1820                                           *
    '*  Author  : K. STUEMPGES ( VIA Bruce Reynolds)                *
    '*  Date    : 27 OCT 2011                                       *
    '*  Notes   : MODIFIED FROM BRUCE REYNOLDS PROGRAM              *
    '*          : TO USE WITH A PIC 16F676A                          *
    '*          : A RELAY WILL BE USED TO CYCLE THE INVERTER        *
    '*          : USED ON THE FREEZER  (ON - OFF WITH HYSTERESIS)   *
    '*          : THE FREEZER TEMP WILL BE FROM 0 TO 15 DEGREES F   *
    DEFINE      OSC 4           ' INTERNAL OSCILLATOR
    TRISC = 000000
    TRISB = 010000
    Comm_Pin    VAR    PORTC.0      ' One-wire Data-Pin "DQ"
    RELAY       VAR PORTC.6      ' OUTPUT TO DRIVE THE RELAY
    '   THIS IS THE OUTPUT THAT WILL NOT STAY HIGH USING ANY OTHER PORT C PIN
    '   IT WORKS FINE USING PORT B
    DISP        VAR PORTC.3      ' SERIAL LCD OUTPUT
    ALARM       VAR PORTB.3      ' OUTPUT TO SOUND ALARM
    SWITCH      VAR PORTB.4      ' TOGGLE SWITCH INPUT
    Busy        VAR BIT         ' Busy Status-Bit
    R_Temp      VAR    WORD        ' RAW Temperature readings
    TempC       VAR WORD        ' Temp in deg C
    TempF       VAR WORD        ' Temp in deg F
    Float       VAR WORD        ' Holds remainder for + temp C display
    Cold_Bit    VAR R_Temp.Bit11' Sign-Bit for +/- Temp. 1 = Below 0 deg C
    Real_Cold   CON 1           ' Define Real_Cold = 1
    Deg         CON 223         ' Data to display Deg ° symbol
    Sign        VAR BYTE        ' +/- sign for temp display
    Dummy       VAR BYTE        ' Dummy for Div32
    CLR         CON 1           ' CLEAR DISPLAY
    LINE1       CON 128         ' FIRST LCD LINE
    LINE2       CON 192         ' SECOND LCD LINE
    LINE3       CON 148         ' THIRD LCD LINE
    LINE4       CON 212         ' FOURTH LCD LINE
    INS         CON 254         ' LCD COMMAND MODE PARAMTER
    BAUD        CON 84          ' LCD BAUD COMMAND
            SEROUT2 DISP,BAUD,[INS,CLR] ' clears the display
    Start_Convert:
        OWOUT   Comm_Pin, 1, [$CC, $44]' Skip ROM search & do temp conversion
    Wait_Up:
        OWIN    Comm_Pin, 4, [Busy]    ' Read busy-bit
        IF      Busy = 0 THEN Wait_Up  ' Still busy..?, Wait_Up..!
        OWOUT   Comm_Pin, 1, [$CC, $BE]' Skip ROM search & read scratchpad memory
        OWIN    Comm_Pin, 2, [R_Temp.Lowbyte, R_Temp.Highbyte]' Read two bytes / end comms
        GOSUB   Convert_Temp
        GOTO    Start_Convert
    Convert_Temp:                 ' +32.0 to +257 F
        IF      Cold_Bit = Real_Cold THEN Yikes ' If Cold_Bit = 1, it's below "0" deg C
        Sign  = "+"
        Dummy = 625 * R_Temp      ' Multiply to load internal registers with 32-bit value
        TempC = DIV32 10          ' Use Div32 value to calculate precise deg C
        Dummy = 1125 * R_Temp
        TempF = DIV32 100
        IF TempF >6795 THEN ' Over 99.5 deg F..?
           TempF = TempF + 3200
    SEROUT2 DISP,BAUD, [INS,LINE1, " Temp = ",Sign,DEC TempF DIG 4,_
           DEC TempF DIG 3,DEC TempF DIG 2,Deg," F  "]
      SEROUT2 DISP,BAUD, [INS,LINE1, " Temp = ",Sign,DEC TempF DIG 3,_
        TempC  = (R_Temp & $0FF0) >> 4 ' Mask middle 8-bits, shift into lower byte
        'Float = ((R_Temp.Lowbyte & $0F) * 625) ' Lower 4-bits of result * 625
      SEROUT2 DISP,BAUD, [INS,LINE2, " Temp = ",Sign,DEC TempC,Deg," C  "]
        RELAY = 1
    '   THIS OUTPUT ONLY STAYS HIGH FOR APROX 20 US.
    '   IT WILL REMAIN ON USING ANY PIN ON PORTB
    Yikes:                      ' Display full range -C to -F conversion
        Sign   = "-"            ' Display - symbol for negative temp
        Dummy  = 625 * ~R_Temp+1' Multiply to load internal registers with 32-bit value
        TempF  = ~R_Temp / 16   ' Begin conversion from -C to deg +/-F
        IF TempF >=18 THEN      ' Check for -degrees F "-18 C = -0.4 F"
           TempF   = ((((TempF + 50) * 9) /5) -122) ' -C to -F below -17 deg C
          SEROUT2 DISP,BAUD, [INS,LINE1, " Temp = ",Sign, DEC TempF,Deg," F  "]
          SEROUT2 DISP,BAUD, [INS,LINE2, " Temp = ",Sign,DEC TempC dig 4,_
          dec TempC dig 3,Deg," C  "]
        ELSE                    ' Else result = +deg F
           TempF   = ((((-TempF + 50) * 9) /5) -58)' -C to +F below 32.0 deg F to -17 deg C
         SEROUT2 DISP,BAUD, [INS,LINE1, " Temp = ","+",DEC TempF,Deg," F  "]
         dec TempC Dig 3,Deg," C  "]
    Default Re: OWIN - OWOUT problem
    "Upon further review" I found that the owin / owout is not causing this weirdness. It seems to be the result of using serout2. I switched ports around, etc, and found that when I have the serial out on the same port as my test LED, that is when the on/off problem occurs. Moving the statement around in the program has no effect.
    I guess I will simply just dedicate one port to the serout2 command, and do everything else on a different port. Thankfully I have spare pins available for what I need to do
    Ken
