Hello
below is my code. i am using pic18f4550. light start to blink as expected but when anything is sent serially it hangs pic and blinking light stops.
any suggestions appreciated.Code:DEFINE RESET_ORG 0x1000 DEFINE OSC 48 adcon1 = 15 DEFINE HSER_RCSTA 90h DEFINE HSER_TXSTA 20h DEFINE HSER_BAUD 9600 SerialData var byte RXIF VAR PIR1.5 TXIF VAR PIR1.4 DEFINE USE_LOWPRIORITY 1 ;--- Setup Interrupts ------------------------------------------------------ INCLUDE "DT_INTS-18.bas" ; Base Interrupt System include "ReEnterPBP-18.bas" include "ReEnterPBP-18LP.bas" ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler USB_Handler endm INT_CREATE ; Creates the interrupt processor INT_LIST_L macro ; IntSource, Label, Type, ResetFlag? INT_Handler RX_INT, _Receive, PBP, no endm INT_CREATE_L endasm @ INT_ENABLE RX_INT ;--- Setup USB ------------------------------------------------------------- INCLUDE "DT_HID260.pbp" DEFINE USB_VENDORID 6017 DEFINE USB_PRODUCTID 2000 DEFINE USB_VERSION 1 DEFINE USB_VENDORNAME "Test" DEFINE USB_PRODUCTNAME "Test" DEFINE USB_SERIAL "001" DEFINE USB_INSIZE 64;32 ; IN report is PIC to PC (8,16,32,64) DEFINE USB_OUTSIZE 64;16 ; OUT report is PC to PIC DEFINE USB_POLLIN 10 ; Polling times in mS, MIN=1 MAX=10 DEFINE USB_POLLOUT 10 ; --- Each USB LED is optional, comment them if not used ---- DEFINE USB_LEDPOLARITY 1 ; LED ON State [0 or 1] (default = 1) DEFINE USB_PLUGGEDLED PORTB,0 ; LED indicates if USB is connected DEFINE USB_TXLED PORTC,2 ; " " data being sent to PC DEFINE USB_RXLED PORTC,1 ; " " data being received from PC main: Toggle porta.0 pause 50 goto main Receive: HSERIN [Serialdata] hserout [Serialdata,13,10] back: @ INT_RETURN
thank you
