Hey group,
I am finally tackling DT's instant INT's
I have been able to get his LED blink sample working using INT_INT (pin RA2 on the 16F690, the external INT pin)
using this code...
But I can not get the interupt to work using RB7(Individually controlled interrupt-onchange.Code:include "ALLDIGITAL.pbp" INCLUDE "DT_INTS-14.bas" ; Base Interrupt System INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts wsave VAR BYTE $70 SYSTEM ' alternate save location for W DEFINE OSC 4 TrisA = %00000100 TrisB = %00000000 TrisC = %00000011 LED0 VAR PORTC.0 'this LED is controlled by the "INT" pin, 16F690=RA2 LED1 var PortC.1 'this LED is controlled by the Main program loop ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler INT_INT, _ToggleLED1, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE INT_INT ; enable external (INT) interrupts Main: PAUSE 1000 Toggle led1 GOTO Main '---[INT - interrupt handler]--------------------------------------------------- ToggleLED1: TOGGLE LED0 @ INT_RETURN
Individually enabled pull-up.)
I have tried several of the various INT choices and the one that seems to compile without errors is RABC_INT. But the program acts weird. I have two LED's one connected to RC0 that should be controlled by the instantINT. And another LED connected to RC1 that should be blinking at a 1 second rate controlled by the "Main" program loop.
Here is the code for that...
LED0 controlled by the "Main" program loop is working correctly.Code:include "ALLDIGITAL.pbp" INCLUDE "DT_INTS-14.bas" ; Base Interrupt System INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts wsave VAR BYTE $70 SYSTEM ' alternate save location for W DEFINE OSC 4 TrisA = %00000000 TrisB = %10000000 TrisC = %00000000 CM1CON0 = 0 'turn off the comparator 1 CM2CON0 = 0 'turn off the comparator 2 OPTION_REG.7=1 'Turn OFF weak pull ups LED0 VAR PORTC.0 'this LED is controlled by the "INT" pin, 16F690=RA2 LED1 var PortC.1 'this LED is controlled by the Main program loop IOCB.7=1 ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler RABC_INT, _ToggleLED1, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE RABC_INT ; enable external (INT) interrupts Main: PAUSE 1000 Toggle led1 GOTO Main '---[INT - interrupt handler]--------------------------------------------------- ToggleLED1: TOGGLE LED0 @ INT_RETURN
LED1 (should be controlled by RB7 INT) does not work correctly... it blinks erratically. ON dim, ON bright and OFF
and the LED1 ONLY blinks if in include this line of code... IOCB.7=1
What am I doing wrong??
How does one know which INT to use??
My goal is to impliment instantINT using a rotary encoder on RB6 & 7, and a third INT for the encoder push-button on RB5.
HELP! please
