Home Theater IR Remote Light Switch
Results 1 to 8 of 8
    Default Re: Home Theater IR Remote Light Switch
    Hi RFEFX - I'm trying to find some examples of using an IR remote to turn on/off a PCB board, kinda like a stereo receiver/TV/DVD box works (the box's remote power button toggles the power on or off but you can also turn it off with the switch right on the box). Could I adapt your code for that purpose (my board runs on 9V DC so not as serious as your AC house mains)
    Nov 2006
    Murrieta, CA
    Well it looks like your doing almost the same thing as i have done.. my board, also running off 9v, it is simply closing contacts on another board (the remote). Can you elaborate on the design or your intent?
    - Gary D.
    There are 10 kinds of people. Those that know binary and those that do not.
    I have a model with a custom circuit board with controls LEDs and motors. I want to be able to turn it on/off with a button on the model itself, or with a remote - exactly like a TV/DVD/stereo. I've never done IR before, but I imagine there will be a dedicated chip hooked up to an IR receiver (running on a button battery? It has to be small because the space in the model's base is tight) and when it receives the power command it completes a relay (latch?) between the 9VDC power supply and the PCB. Does that make sense?
