programming multiple DS1337
Results 1 to 4 of 4
    Dec 2005
    Default Re: programming multiple DS1337
    P13 of datasheet...
    The slave address byte contains the 7-bit DS1337 address, which is 1101000, followed by the direction bit (R/W), which, for a write, is 0.
    Sep 2006
    talks about slave mode and master mode, read and write. I dont see multiple ds1337 programming..
    Dec 2005
    All DS1337s have that address. I've never seen an I2C RTC that allowed you to change the address. Normally, there's no need for multiple RTCs.
    Why are you trying to use multiple RTC chips?
