PID help
Results 1 to 2 of 2
Thread: PID help
    Default PID help
    Hello,
    I found this snippet of code for a PID written in picbasic. I need some help understanding a few things....
    1). What size are the variables? byte, word..?
    2). I don't want to use the X2 board. I have a PWM port set up for PWM driving an H-bridge using portb.0 and portb.1 for forward/reverse directions using 16F877A. How would I change the code to reflect the internal PWM and portb direction bits?
    3). What is going on with the LOOKUP bit of code? What is it trying to do?
    I am running a small electronic motor off of AA batteries, I am creating a servo.
    Best Regards,
    Nick
    PID-Control-Implementation-1.doc
    Bombay, India
    Default Re: PID help
    Nick,
    Let me try to answer your questions
    1 - Word
    2 - Very simply, if Drive is a positive value, you move forwards, and vice versa
    The pwm magnitude can be set by the ABS(Drive) value
    3 - The LOOKUP command is checking if the value in Drive is positive or negative and filling Direction with either f or r.
    Understandably, the board wants the direction input to it as either 'f' or 'r' for forward or reverse
