Changing LCD display refresh rate
Results 1 to 11 of 11
    Default Re: Changing LCD display refresh rate
    There is no @ int_return at the end?
    I already use a timer1 DT interrupt, this one will not affect my program?
    Note : I use a 40MHz xtal, and my LCD desired refresh rate is about 0.5s.
    Sep 2005
    Campbell, CA
    The ISR is not written in PBP. It is in assembly. The only INT_RETURN you need is at the end of the interrupt service routine - just before the ENDASM.
    For 40Mhz -
    Lines you need to change
    DEFINE OSC 40
    T0CON = %10000011 ; Turn timer on, divide by 16 prescaler
    movlw 0x0B ; 100 mSec @ 40MHz
    movwf TMR0H
    movlw 0xDC
    movwf TMR0L
    If MasterClock >= 5 then ; 5 X .1 sec = .5 seconds
    And no, it will not affect anything else you have running.
    Charles Linquist
    Ok, so I've integrated a very simple counter whos counts the number of loops and refresh the LCD after a certain amount of loops :
    ' Main entire program loop
    lp:
    ' Start ADC conversion
    ADCON0.1=%1
    WHILE ADCON0.1=%1:WEND
    ' Store ADC results
    isense.HIGHBYTE=ADRESH
    isense.LOWBYTE=ADRESL
    usense.HIGHBYTE=ADRESH
    usense.LOWBYTE=ADRESL
    tsense.HIGHBYTE=ADRESH
    tsense.LOWBYTE=ADRESL
    psense.HIGHBYTE=ADRESH
    psense.LOWBYTE=ADRESL
    ' Security fault verifications
    IF isense**40000>imax THEN flt=1
    IF usense>880 THEN flt=2
    IF tsense>880 THEN flt=3
    ' Security fault tripping
    IF flt>0 THEN GOTO fltsub
    ' Brake/surge resistor control
    IF usense>800 then
       if run=%1 then high PORTD.7
        LOW PORTD.7
    ' Frequency reference control by potentiometer
    psense=((psense<<6)**maxf)+10
    IF psense<>freq+10 THEN freq=psense:flag=%1
    ' Frequency limits
    IF freq<minf THEN freq=minf
    IF freq>maxf THEN freq=maxf
    ' Recalculations
    IF flag=%1 THEN
       ' Reload timer calculation
       dum=dum1*dum2
       stor=DIV32 freq
       rld=(65535-stor)+8
       ' U/F calculation
       IF freq<=500 THEN
          amp=(freq*131)+35
           amp=65535
      flag=%0
    ' Run
    IF run=%1 THEN
       IF flag1=%0 THEN PWMCON0.6=%1:HIGH PORTD.6:flag1=%1
    ' Stop
    IF run=%0 THEN
       IF flag1=%0 THEN PWMCON0=%0:LOW PORTD.6:flag1=%1
    ' FWD rotation
    IF rot=%1 THEN
       IF flag2=%0 THEN ustep=89:vstep=59:wstep=29:write 0,rot:flag2=%1
    ' RWD rotation
    IF rot=%0 THEN
       IF flag2=%0 THEN ustep=29:vstep=59:wstep=89:write 0,rot:flag2=%1
    ' - button
    IF PORTE.0=%1 then
       if flag8=%0 then
          IF menu=%0 THEN mpos=mpos-1:d=1200:E=%0:F=%0
       flag8=%1
    ' + button
    IF PORTE.1=%1 then
       if flag9=%0 then
          IF menu=%0 THEN mpos=mpos+1:d=1200:E=%0:F=%0
       flag9=%1
    ' Run/stop button
    IF PORTC.0=%1 THEN
       IF run=%0 AND mpos<6 AND flag3=%0 THEN run=%1:flag1=%0:flag3=%1:f=%0
       IF run=%1 AND flag3=%0 THEN run=%0:flag1=%0:flag3=%1:f=%0
    ' FWD/RWD button
    IF PORTC.1=%1 THEN
       IF rot=%0 AND run=%0 AND flag4=%0 THEN rot=%1:flag2=%0:flag4=%1
       IF rot=%1 AND run=%0 AND flag4=%0 THEN rot=%0:flag2=%0:flag4=%1
    ' Menu/OK button
    IF PORTC.2=%1 THEN
       IF menu=%0 AND run=%0 AND mpos>5 AND flag5=%0 THEN menu=%1:flag5=%1
       IF menu=%1 AND flag5=%0 THEN menu=%0:flag5=%1
    ' Buttons released state
    IF PORTC.0=%0 THEN flag3=%0
    IF PORTC.1=%0 THEN flag4=%0
    IF PORTC.2=%0 THEN flag5=%0
    IF PORTE.0=%0 THEN flag8=%0
    IF PORTE.1=%0 THEN flag9=%0
    ' LCD first line writing
    c=c+1
    if c>800 then
       IF rot=%1 THEN LCDOUT $fe,$2,"+"
       IF rot=%0 THEN LCDOUT $fe,$2,"-"
       LCDOUT DEC freq DIG 3,DEC freq DIG 2,DEC freq DIG 1,".",DEC freq DIG 0,"Hz"
       IF run=%1 THEN LCDOUT REP 32\5,"RUN"
       IF run=%0 THEN LCDOUT REP 32\4,"STOP"
       c=0
    ' Inverter menu (LCD second line writing)
    SELECT CASE mpos
    ' Menu limits
    IF mpos<1 THEN mpos=1
    IF mpos>11 THEN mpos=11
    IF run=%1 THEN
       IF mpos>5 THEN mpos=5
    ' Current sensing submenu
    CASE 1
    d=d+1
    if d>1200 then
       idisp=isense**40000
       lcdout $fe,$c0,$1,$20,"1 ISENS: ",DEC idisp DIG 2,DEC idisp DIG 1,".",DEC idisp DIG 0,"A"
       d=0
    ' Voltage sensing submenu
    CASE 2
    d=d+1
    if d>1200 then
       udisp=usense**29600
       lcdout $fe,$c0,$1,$0,"2 USENS: ",DEC3 udisp,"V",32
       d=0
    ' Temperature sensing submenu
    CASE 3
    d=d+1
    if d>1200 then
         tdisp=(tsense-280)/8
         lcdout $fe,$c0,$1,$0,"3 TEMP: ",DEC tdisp DIG 1,DEC tdisp DIG 0,$df,"C",REP $20\2
         d=0
    ' Last fault reading submenu
    CASE 4
    if e=%0 then
       lcdout $fe,$c0,$1,$0,"4 LASTFAULT: ",DEC1 lastf
       e=%1
    ' Firmware version reading submenu
    CASE 5
    IF run=%1 THEN
       IF f=%0 then
          lcdout $fe,$c0,$1,$20,"5 FW: V2011.00"
          f=%1
    IF run=%0 THEN
       IF F=%0 THEN
          lcdout $fe,$c0,$1,$0,"5 FW: V2011.00"
          f=%1
    ' Maximum frequency adjust submenu
    CASE 6
    IF menu=%1 THEN
       Lcdout $fe,$c0,$3e,$3e,"A MAX: ",DEC maxf DIG 3,DEC maxf DIG 2,DEC maxf DIG 1,".",DEC maxf DIG 0,"Hz"
       BUTTON PORTE.0,1,200,10,a,0,ret
              IF maxf>minf THEN maxf=maxf-1
       ret:
       BUTTON PORTE.1,1,200,10,b,0,ret1
              IF maxf<1200 THEN maxf=maxf+1
       ret1:
       flag6=%0
        lcdout $fe,$c0,$1,$0,"A MAX: ",DEC maxf DIG 3,DEC maxf DIG 2,DEC maxf DIG 1,".",DEC maxf DIG 0,"Hz"
        if flag6=%0 then write 1,maxf.HIGHBYTE:write 2,maxf.LOWBYTE:flag6=%1
    ' Minimum frequency adjust submenu
    CASE 7
    IF menu=%1 THEN
       Lcdout $fe,$c0,$3e,$3e,"B MIN: ",DEC minf DIG 3,DEC minf DIG 2,DEC minf DIG 1,".",DEC minf DIG 0,"Hz"
       BUTTON PORTE.0,1,200,10,a,0,ret2
              IF minf>10 THEN minf=minf-1
       ret2:
       BUTTON PORTE.1,1,200,10,b,0,ret3
              IF minf<maxf THEN minf=minf+1
       ret3:
       flag6=%0
        lcdout $fe,$c0,$1,$0,"B MIN: ",DEC minf DIG 3,DEC minf DIG 2,DEC minf DIG 1,".",DEC minf DIG 0,"Hz"
        if flag6=%0 then write 3,minf.HIGHBYTE:write 4,minf.LOWBYTE:flag6=%1
    ' Current trip adjust submenu
    CASE 8
    IF menu=%1 THEN
       Lcdout $fe,$c0,$3e,$3e,"C ITRIP: ",DEC imax DIG 2,DEC imax DIG 1,".",DEC imax DIG 0,"A"
       BUTTON PORTE.0,1,200,20,a,0,ret4
              IF imax>0 THEN imax=imax-1
       ret4:
       BUTTON PORTE.1,1,200,20,b,0,ret5
              IF imax<150 THEN imax=imax+1
       ret5:
       flag6=%0
        lcdout $fe,$c0,$1,$0,"C ITRIP: ",DEC imax DIG 2,DEC imax DIG 1,".",DEC imax DIG 0,"A"
        IF flag6=%0 THEN write 5,imax:flag6=%1
    ' PWM carrier frequency adjust submenu
    CASE 9
    IF menu=%1 THEN
       Lcdout $fe,$c0,$3e,$3e,"D PWMFREQ: ",DEC1 pwmf,REP $20\2
       BUTTON PORTE.0,1,200,50,a,0,ret6
              IF pwmf>1 THEN pwmf=pwmf-1
       ret6:
       BUTTON PORTE.1,1,200,50,b,0,ret7
              IF pwmf<4 THEN pwmf=pwmf+1
       ret7:
       flag6=%0
        lcdout $fe,$c0,$1,$0,"D PWMFREQ: ",DEC1 pwmf,REP $20\2
        IF flag6=%0 THEN write 6,pwmf:GOSUB pwmsub:flag6=%1
    ' LCD backlight submenu
    CASE 10
    IF menu=%1 THEN
       Lcdout $fe,$c0,$3e,$3e,"E BACKLIGHT: ",DEC1 bl
       IF PORTE.0=%1 then
          IF bl=%1 THEN bl=%0
       if PORTE.1=%1 then
          IF bl=%0 THEN bl=%1
       flag6=%0
        lcdout $fe,$c0,$1,$0,"E BACKLIGHT: ",DEC1 bl
        IF flag6=%0 THEN write 7,bl:GOSUB blsub:flag6=%1
    ' Reset all settings submenu
    CASE 11
    IF menu=%1 THEN
       IF flag7=%0 THEN
          rot=%1:write 0,rot
          maxf=500:write 1,maxf.HIGHBYTE:write 2,maxf.LOWBYTE
          minf=10:write 3,minf.HIGHBYTE:write 4,minf.LOWBYTE
          imax=150:write 5,imax
          pwmf=3:write 6,pwmf:GOSUB pwmsub
          bl=%1:write 7,bl:GOSUB blsub
          Lcdout $fe,$c0,$3e,$3e,"F RESET? OK",REP $20\3:flag7=%1
        IF menu=%0 THEN lcdout $fe,$c0,$20,$0,"F RESET?",REP $20\6:flag7=%0
    END SELECT
    GOTO lp
    It's working very well, the gain of speed of the loop is incredible (about ten times faster than the old program).
    But sometimes, when I navigate into the menu, the LCD freeze and the PIC "resets". I don't know why. What's happen?
