First time using comparators DT interrupts
Results 1 to 6 of 6
    May 2008
    Italy
    Default First time using comparators DT interrupts
    I am trying some experiments using both comparators on pic 16F88 (mind you my first time), where I need interrupts. It seems I am unable to compile due to some errore with the interrupt.
    Below the code and the errors at the end of compilation (same thing with PBP 2.47 and PBP3)
    INCLUDE "DT_INTS-14.bas"        ; Base Interrupt System
    'INCLUDE "ReEnterPBP.bas"        ; Include if using PBP interrupts
    DEFINE OSC 20
    CMCON = %00000100
    TrisA = %00001111
    TrisB = %00000000
    PortB = 0
    Led                 var PortB.3
    Flag                var bit
    wsave               VAR BYTE    $70     SYSTEM  ' alternate save location for W
    Q_New               var Byte
    Q_Old               var byte
    Q_Count             var word
    ' Set variable value @ startup
       Flag = 0
      Q_New = 0
      Q_Old = 0
    Q_Count = 0
    INT_LIST  macro    ; IntSource,        Label,  Type, Resetflag?
            INT_Handler    CMP1_INT  _Encoder,   ASM,  yes
            INT_Handler    CMP2_INT  _Encoder,   ASM,  yes
        INT_CREATE                   ; Creates the interrupt processor
    @ INT_ENABLE CMP1_INT            ; enable comp1 (INT) interrupts
    @ INT_ENABLE CMP2_INT            ; enable comp2 (INT) interrupts
    Goto Main_Loop
    Encoder:
       Q_New = CMCON.7 + CMCON.7 + CMCON.6
    if Q_Old = 0 then
    if Q_New = 2 then Minus_Count
    if Q_New = 1 then Plus_Count
    if Q_Old = 1 then
    if Q_New = 0 then Minus_Count
    if Q_New = 3 then Plus_Count
    if Q_Old = 3 then
    if Q_New = 1 then Minus_Count
    if Q_New = 2 then Plus_Count
    if Q_Old = 2 then
    if Q_New = 3 then Minus_Count
    if Q_New = 0 then Plus_Count
    goto Q_Skip
    Minus_Count:
     Q_Count = Q_Count - 1
    goto Q_Skip
    Plus_Count:
     Q_Count = Q_Count + 1
    Q_Skip:
       Q_Old = Q_New
         Led = !Led
    @ INT_RETURN
    Main_Loop:
    goto Main_Loop
    Surely is something due to my inexperience with comparators, so need some help. Any suggestion is welcome.
    Cheers
    Al.
    Default Re: First time using comparators DT interrupts
    Hi Al,
    The 16F88 doesn't have separate interrupt flags for the 2 comparators.
    Both comparators use the same flag.
    So with DT_INTS, use the single CMP_INT handler.
    May 2008
    Italy
    Thank you Darrel for the quick answer.
    Cheers
    Al.
    May 2008
    Italy
    Used CMP_INT without any luck. Stil getting two asm errors :
    553 - missing argument
    472 - "INT_HANDLER" interrupt flag not found.
    Any suggestion?
    Cheers
    Al.
    Al,
    I think you just need a comma in your INT_Handler line.
            INT_Handler    CMP_INT,  _Encoder,   ASM,  yes
    May 2008
    Italy
    Yes Darrel, it was just the comma missing. Thank you again.
    Cheers
    Al.
