LCD going crazy!!!
Results 1 to 13 of 13
    Bombay, India
    Default Re: LCD going crazy!!!
    Question time:
    1 - How is your circuit built? Breadboard? or a proper PCB?
    2 - How about decoupling capacitors. Do you have them 0.1uF across the supply rails?
    3 - How are you powering the circuit? Chances are you have a bad ac adapter (assumption)
    I know I'm asking the obvious, but, in times of stress, you need to recheck these.
    regards
    Jerson
    Sep 2006
    I am using a breadboard, powered from a 12v battery and a 10uf 16v rail to rail cap. I might redo the circuit on another breadboard using different wires and parts tonight..
    k
    Sep 2006
    Changed the breadboard and all parts. Works perfectly now. I think the breadboard might be damaged...
    ken
