LCD going crazy!!!
Results 1 to 13 of 13
    Sep 2006
    Default LCD going crazy!!!
    This is a test program for my LCD. Sometime I can read on the screen but the following second the words are jumping from one line to another and the letters and just going about anywhere... any thoughts
    'LCD testing program
    INCLUDE "modedefs.bas"
    OSCCON = %01110000 '8 Mhz
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    '// LCD configuration //
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTA ' Set LCD Register Select port
    DEFINE LCD_RSBIT 2 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTA ' Set LCD Enable port
    DEFINE LCD_EBIT 3 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    Mainloop:
            lcdout $FE,1, " This is a test"                    '
            lcdout $FE,$C0, "Next or Select"                 '
            pause 200
    GOTO Mainloop
    Bombay, India
    Default Re: LCD going crazy!!!
    Just thinking aloud. Have you tried telling PBP
    define OSC 8
    so that it knows you are working at 8MHz and can adjust its timings accordingly.
    bjsunbeam's Avatar
    bjsunbeam Guest
    try a pause between each lcd out
    Some of the cheaper LCD's are not good with fast transfers
    You can also try adjusting the LCD commandUs etc
    Sep 2006
    I did try using define, same thing happens. I have been using this LCD for a couple of years now. This is happening since I upgraded to windows7 64 bit. and using microcode studio
    K
    Sep 2006
    I also changed pic, used different pins for RS RE LCDout. I just have not changed the LCD module with a new one.. maybe its the LCD ...
    Nov 2007
    West Covina, CA
    How about:
    Mainloop:
            LCDOUT $FE,1    ' Clear display
            PAUSE 50
            LCDOUT $FE,2," This is a test"       ' Move to 1st line, writes 15 CHAR
            LCDOUT $FE,$C0,"Next or Select"     ' Move to 2nd line, writes 14 CHAR
            PAUSE 200
    GOTO Mainloop
    Louie
    Bombay, India
    taking a cue from Louie, I'd say, you're writing too fast for the lcd to keep pace.
    You can try this
    Mainloop:
    STOP
