I thought this would be simple (average time between 4 switch presses)
Results 1 to 7 of 7
    Feb 2010
    USA, New England
    Default Re: I thought this would be simple (average time between 4 switch presses)
    Hi Hank,
    Late to the game (as usual) and probably haven't read thoroughly enough, but why should that stop me from commenting? 8^)
    You said that the times will always be less than 1 second and that the timer can hold just a little more than half a second. Why not clear the overflow flag at the same time you clear the timer. Then when you read the timer also check the overflow flag. If it is set, add $FFFF to your value. The interrupt flags work whether they are used to trigger an actual interrupt or not.
    Best Regards,
    Paul
    Mar 2009
    Hi Paul,
    Stonking late entry - many thanks!!
    Hank.
