Pic16f88 compiling. . not working
Results 1 to 15 of 15
    Sep 2006
    Default Re: Pic16f88 compiling. . not working
    I dont have microcode studio, just MPLab and a plain text editor..
    Micro Code Studio ships with PBP. It is on your install CD.
    Sep 2006
    Here is the configuration I have:
Size:  440.1 KBName:  mcs2.jpg
    Sep 2007
    USA, CA
    Did you notice that it selected the assembler from your recycle bin?
    Also, it has been several years since I worked with the 16f88, but iirc it has at least one of the peripherals enabled by default. You must go through each and every pin used with the lcd and make sure it is configured to be a regular i/o pin, and not configured as a peripheral pin.
    Sep 2006
    Yes I saw it refers to the recycling bin. although it does not find it automatically. and I do not know what to choose. The help file in the micro code studio is not very helpful in that regard.
    k
    Sep 2006
    by removing this line:
    @ DEVICE pic16F88, INTRC_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON
    the code compiles but does not create the hex file !!
    k
    MPASM should be C:\Program Files\Microchip\mpasm suite
    or something like that.
    Sep 2006
    I installed version 4 of microCode studio, now it creates the Hex file.
    Aleluia !!
    K
