Hello,
I am trying to figure how to use MPLAB in windows 7. Have installe MPLAB version 8.63 along with picbasic pro 2.60C. My following code compiles with no error:
'LCD testing program
OSCCON = %01110000 '8 Mhz
DEFINE OSC 8
'// LCD configuration //
DEFINE LCD_DREG PORTB ' Set LCD Data port
DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSREG PORTA ' Set LCD Register Select port
DEFINE LCD_RSBIT 2 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTA ' Set LCD Enable port
DEFINE LCD_EBIT 3 ' Set LCD Enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
DEFINE CHAR_PACING 2000
Mainloop:
lcdout $FE,1, " This is a test" '
lcdout $FE,$C0, "Next or Select" '
pause 200
GOTO Mainloop
Although it do not seems to work, nothing is showing on the LCD screen, just turns on.
Using Pic16F88. Tried different chip, rewired.. nothing. any ideas ?
Ken
