Modifications in the charger circuit for 4,6 & 8 volts
Results 1 to 3 of 3
    Feb 2014
    Smile Modifications in the charger circuit for 4,6 & 8 volts
    Hello sir
    Here i ve got a charger circuit diagram for 12 volts battery . .
    Now i want to design the same thing for
    1) 4 volts
    2) 6 volts
    3) 8 volts
    So what modifications does component's value need in above 3 cases ?
    please tell ! thanks
    Default Re: Modifications in the charger circuit for 4,6 & 8 volts
    Here's all the math you need:
    http://www.eleccircuit.com/lm338-lm3...or-calculator/
    Best Regards.
    Oct 2011
    With P1 centered the circuit should give output of 14v or about 2.3v per cell. For a 6v battery you will need an output of 7v, 8v - 9.3v, 4v - 4.7v. The output voltage is set by potential divider R3 and R4/P1.
    Here is what I would do.
    Replace R4 with a 47k pot set at 47k and set P1 mid position. Power on the circuit and decrease the setting of the pot until the output voltage is the required value. Replace the pot with the nearest value fixed resistor. Adjust P1 to get the exact voltage required.
    Phil
  1. upg D1730 automatic lead acid battery charger circuit board 12v 500ma
    By koenton in forum FAQ - Frequently Asked Questions
    Last Post: - 9th June 2012, 18:28
  2. Replies: 14
    Last Post: - 6th March 2011, 06:08
  3. Charger Circuit
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2009, 15:38
  4. Replies: 11
    Last Post: - 6th November 2008, 11:27
  5. 16F628 & In-Circuit Programming?
    By Len in forum mel PIC BASIC Pro
    Last Post: - 19th March 2004, 14:02
