128 bit variable???
Results 1 to 5 of 5
    Sep 2007
    Default Re: 128 bit variable???
    Henrik,
    I really appreciate it. I haven't used arrays before, so this will be good learning for me.
    So what is the $55 ?
    I sort of understand how the loop is adding to the array in each pass. But assuming I use the 'myByteArray' for my 3 bytes I need to combine (Var1, Var2, Var3) that are already saved after reading the status of the 3 ports. How does the loop know to look at these 3 variables?
    Second, question: If the 128 bits is coming in on PortB.1 how does the bottom loop know to read that?
    Thank you very much.
    Hylan
    The $55 is nothing in particular, just a number like any other number fitting into a byte, could have been 85 or 010101 (they are all the same thing by the way). It was just a number I took it doesn't mean or do anything in paricular in the example.
    There are many ways to put Var1-Var3 in the array. The most obvious would be to simply copy them:
    myByteArray[0] = Var1
    myByteArray[1] = Var2
    myByteArray[2] = Var3
    Another, perhaps more elgant way is to create aliases pointing into the array
    myByteArray VAR BYTE[3]
    Var1 VAR myByteArray[0]
    Var2 VAR myByteArray[1]
    Var3 VAR myByteArray[2]
    This way you can use FOR-NEXT loops etc to index the array AND access each entry just like any other byte. Remember that in this case there are only three bytes in RAM, Var1 is the same as myArray[0] - just another 'name' for it - for convinience. Like
    myByteArray[0] = 128
    HSEROUT[#Var1, 13]
    The first line puts the value 128 in the first location of the array. The second line prints the content of Var1 which is the same thing as the first location of the array.
    If your databits are comming in on PortB.1 and, I assume you have some sort of clock or something on PortB.0, then something like:
    Counter = 0
    While Counter < 128
      While PortB.0 = 0 : WEND 'Wait here for rising edge of clock.
      myBitArray[Counter] = PortB.1 'Get state of pin and store in array
      While PortB.0 = 1 : WEND ' Wait for clock to return low
      Counter = Counter + 1 ' Prepare for next bit
    WEND
    Something like that...
    Sep 2007
    Henrick,
    This is very helpfull. I just got Hyperterminal running so I can see the output. I will begin trying this out.
    Thank you! Thank you!
    Hylan
