Bluetooth module @ 3.3 volts
Results 1 to 10 of 10
    Default Re: Bluetooth module @ 3.3 volts
    If the current isn't too high, the MAX6349 LDO is SOT23-6 and only needs one 1µF cap (available in 805 SMD).
    Right Dave, the MAX LDO looks just right, the current doesnt go beyond 20ma. In retorspect, I should have ordered these instead http://www.ebay.com/itm/Serial-Bluet...item3cbd9d88b2 ; 5v ready, and come mounted on a breakout PCB with standard 0.1' pins.
    Still might, but then I'll have to endure a 20 day wait till they arrive
    If you have the a 317 do it your self with 2 resistors or one resistor and a trimmer.
    Even cheaper and easier, a serial pass transistor with a bias to control the output.
    Think the BT module is about 100 MA in Xmit, also, need the SPP (serial port profile mode) on PC which just adds serial ports in Devices-ports (sort of virtual serial port). Sometimes comes with BT drivers.
    Don
    Moved from Schematics.
