Max value for raw is 1024? assuming 10 bit a/d. 1024/10=102. this is ALWAYS less the 205. So you will never be able to turn on the LED. If its a 12 bit A/D, then IDK
-Bert
You are correct and I did remove the /10.
However, the fix was left vs right justification of the result. It works as expected.
