Really simple test program not working.
Results 1 to 3 of 3
    Feb 2004
    Michigan, USA
    Default Really simple test program not working.
    18F2550 20mhz HSPLL set up for USB
    PIC functions and pcb is fine. I can get a simple blinky light to work. I can get a correct ADC value to write to EEPROM and read through the programmer, but I cant get it compare the ADC value with the value stored in fb and turn on or off the LED as I vary the voltage in the ACD pin.
    What the heck am I missing?
    define OSC 48
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    raw var word
    raw1 var word
    fb var word
    fb = 205
    ADCON1 = 001011
    ADCON2 = 000011
    TRISA = 001111
    TRISB = 110000
    TRISC = 000000
    PORTC.2 = 0
    adcin 0, raw
    raw1 = raw/10
    if raw1 => fb then
    Portc.0 = 1
    portc.0 = 0
    goto main]
    Aug 2010
    Maryland, USA
    Default Re: Really simple test program not working.
    Max value for raw is 1024? assuming 10 bit a/d. 1024/10=102. this is ALWAYS less the 205. So you will never be able to turn on the LED. If its a 12 bit A/D, then IDK
    -Bert
    Feb 2004
    Michigan, USA
    You are correct and I did remove the /10.
    However, the fix was left vs right justification of the result. It works as expected.
