User Selectable LED Brightness
Results 1 to 7 of 7
    Feb 2004
    Germany
    Steve,
    There are many possible ways.
    Before I post a ready to run solution, I'll give you a hint that should help you to get started and let you do some homework.
    You could assign an extra variable (Flag VAR BIT) to memorize what the last action performed was: "increase" or "desrease" brightness.
    Dependend on FLAG you enter the decrease or increase loop when the button is pressed.
    Have you checked Presetting Configuration Fuses
    Let us know how you are getting on.
    regards
    Ralph
    Feb 2005
    Essex, UK
    Thank for the 'Hint', this is what i have come up with so far. I think i am along the right lines, but when you hit the button, it continously dims to OFF and there it stays. Am i on the right lines, before i go off on a tangent ?? Can you suggest anymore hints??
    Heres what i have:
    TRISB = %10000001   ' Set PORTB (0)INPUT (1-5)OUTPUTS
    CMCON = 7
    SecSwitch   VAR PORTA.5
    Red         VAR PORTB.1
    Bright      VAR Byte
    storedloop  VAR Byte
    flag VAR Byte
    bright = 254
    flag = 0
    Low red
        If secswitch = 0 then gosub pwmroutine
    Goto Main
    PWMRoutine:
         While (Bright !=255) and (flag = 0)
              PWM red,Bright,5
              bright = bright - 1
         Wend
         While (bright !=0) and (flag = 1)
              PWM red,Bright,5
              bright=bright + 1
         Wend
    Flash:
    For storedloop = 1 to 3
            High red
            Pause 100
            Low red
            Pause 100
    Next storedloop
    Cheers,
    Feb 2004
    Germany
    Steve,
    there is a number of things wrong now.
    in your main loop there will be no PWM output until you press the button.
    Once you have pressed the button it will execute the "decrease brighness" loop since flag=0
    (flag is always 0 in your case!!!)
    Since you don't check for "key still pressed?" in the While...Wend Loop
    it counts bright from 254 (preset value) down to zero.
    with the next decrement (down from zero) bright will be 255.
    From there on none of the conditions to output PWM
    is true or will ever become true. so nothing happens
    regards
    Ralph
    Feb 2004
    Germany
    Steve,
    regarding your PM,
    I think it has all been discussed alredy there
    regards
    Ralph
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. LCD will not start
  5. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 14:27
