Thank for the 'Hint', this is what i have come up with so far. I think i am along the right lines, but when you hit the button, it continously dims to OFF and there it stays. Am i on the right lines, before i go off on a tangent ?? Can you suggest anymore hints??
Heres what i have:
TRISB = %10000001 ' Set PORTB (0)INPUT (1-5)OUTPUTS
CMCON = 7
SecSwitch VAR PORTA.5
Red VAR PORTB.1
Bright VAR Byte
storedloop VAR Byte
flag VAR Byte
bright = 254
flag = 0
Low red
If secswitch = 0 then gosub pwmroutine
Goto Main
PWMRoutine:
While (Bright !=255) and (flag = 0)
PWM red,Bright,5
bright = bright - 1
Wend
While (bright !=0) and (flag = 1)
PWM red,Bright,5
bright=bright + 1
Wend
Flash:
For storedloop = 1 to 3
High red
Pause 100
Low red
Pause 100
Next storedloop
Cheers,
