Re: Programmer configuration...
Originally Posted by
mcbeasleyjr
Could you explain to me why a USB programmer isn't using LVP?
This next quote is taken from the Melabs web page, http://melabs.com/support/icsp.htm
4. Make sure the "low-voltage programming" pin is pulled to ground. Low-voltage programming is not used by melabs programmers and should always be disabled in the configuration settings. Even so, the low-voltage programming pin (labeled PGM or LVP) should be pulled to ground when programming. If it is left floating or in a high condition, it may interfere with the programming process. We use a 100K resistor to pull the pin low when designing a board for ICSP. For most 16F series parts, RB3 doubles as the PGM pin. On 18F series, it is usually RB5 that needs to be low. Notable exceptions are the 16F62x and 16F64x family, which need RB4 to be pulled low.
Anonymous
