A rant about port configurations
Results 1 to 24 of 24
    Sep 2008
    Maine, USA
    Default A rant about port configurations
    I have a pet peeve about how Microchip writes their datasheets.
    I don't know about most folks, but the first thing that I need to know when I'm getting to know a new chip is what the default configurations are for the ports. Most of the time I don't need half the special features that come with the chip, I just need sufficient memory and lots of digital I/O. So I have to wade through hundreds of pages to try and figure out what the default configuration is for each port so I can disable the features that just get in the way of using the port for simple digital I/O.
    Why the heck can't they put a simple page in every spec sheet that lists what the POR config is per port? It would look something like this:
    PortA:
    All pins digital I/O
    PortB:
    All pins digital I/O with pull-ups enabled
    PortC:
    These special features are enabled....
    Is it just me, or does anyone else struggle with this issue?
    "Do or do not, there is no try" Yoda
    Sep 2005
    Campbell, CA
    Default Re: A rant about port configurations
    I'm with you on this one. Every time I get a new chip I type in every register name (usually about a hundred), and look at each bit. I generally I wind up configuring all 800 bits, because I don't look at the POR defaults much, I just set them the way I need them. The whole process takes 4-5 hours, and is getting worse with some of the new "J" and "K" series parts. One upside - I learn a lot about the new part.
    Charles Linquist
    Aug 2010
    Maryland, USA
    I know I may ba a little wierd, but I like reading them. Admitedly I don't read the parts I never use, like ethernet and such. I usually zoom straight for the osc section after looking at the pinout section. From there I will read the example for each port I/O it usually tells me what needs setup to make it work. I like the charts that show each pin and what it can do, this way I know where to look to see if I need to set stuff.
    I HATE writing headers for the initial set up, hence my wish list item for a header wizard. I think it could knock your 4-5 hours down to 10 mins.
    -Bert
    Sep 2005
    Campbell, CA
    It should be possible for uChip or someone else to write such a wizard - maybe they already have. If I was really good at some 'useful' language like Java, I might try it myself. As it is, I'm going to have to wait for someone smarter than me to do it.
    Charles Linquist
    Aug 2010
    Maryland, USA
    I am on that list with you. But I don't agree with the useful part. You already know the most useful language - PBP. The rest can only make pretty pictures and parse text.
    -Bert
    I highly dislike the method of trying to initialize ALL the registers at the top of your program.
    Unless you know EVERYTHING about that chip, many of them get initialized incorrectly.
    This had led to more problems than any other issue.
    With the exception of comparators on the older chips ... Everything is turned OFF at power-up.
    All you have to do is turn ON the things you want to use.
    Don't try to turn everything off, they already are.
    Now the first thing people will say is ...
    Then why do I have to turn off analog pins with ADCON1 or ANSELx?
    It's because you aren't turning the Analog functions OFF, you are turning the Digital Inputs ON.
    Analog inputs are always ON, even when the Digital Input is enabled.
    So just concentrate on what you want the chip to do, not what you don't want it to do.
