Hi, thanks for the reply,
I'm trying to run the quick start steps under the link on the PICkit 2 CD "Click here for Quick Start in BASIC with the PICBASIC PRO Demo Compiler"
I was following these instructions:
"PICBASIC PRO Quick Start
PICkit™ 2 Starter Kit
Get started programming in BASIC with a demonstration version of the
microEngineering Labs, Inc. PICBASIC PRO Compiler for Microchip PIC® MCUs.
This demo version supports a limited number of instructions on a limited set of
devices, including the Starter Kit’s PIC16F690.
I get to the part where I compile the file "pk2_tutorial.bas" and I get the error:
- Install MPLAB® IDE using the included installation disc.
(Use the default install options. Skip if already installed)- Install the PICBASIC PRO Compiler Demo
- Install PICkit™ 2 Lessons for the Low Pin Count Demo Board
Included with the Lessons is a BASIC project used in the Getting Started Guide.- See the Getting Started with PICBASIC PRO guide to complete PICBASIC PRO
setup with the MPLAB IDE, create a BASIC language project in MPLAB,
compile demonstration code, and program it using the Low Pin Count
Demo Board."
"Executing: "C:\PBPDEMO\PBPWDEMO.EXE" -ampasmwin -oq -z -p16F690 "pk2_tutorial.bas"
PICBASIC PRO(TM) Compiler Demo, (c) 1998, 2007 microEngineering Labs, Inc.
All Rights Reserved.
For more information, including purchase info, for this product,
visit melabs.com or call microEngineering Labs, Inc. at 719-520-5323.
ERROR: Unable to execute mpasmwin.Halting build on first failure as requested.
BUILD FAILED: Wed Oct 19 19:03:37 2011
Does this help?
Alternatively, I have just found the "SK Getting Started in MPLAB" pdf, and the associated MPLAB lessons, so I might be able to proceed with this instead.
Thanks again,
Graham
