16F1827 interrupt hosed
Results 1 to 19 of 19
    Aug 2010
    Maryland, USA
    Default Re: 16F1827 interrupt hosed
    BSR will be restored when you exit the ISR. That chip auto saves and restores W,PC,Status, BSR, I think. So no need to worry about it from the Main point of view. I have not checked the banks you are using in the ISR, but I am thinking since it works sometimes they may be all in BANK 0. Could be the ADC is whats creating the NON bank 0 setting in the BSR.
    -Bert
    Bert,
    Thanks for the help. I used your suggestion in conjunction with BANKSEL T1CON at the start of the ISR after the ASM tag. It all works now!!!
    Nick
    Aug 2010
    Maryland, USA
    do you understand why? sounds like you do. BTW DT_INT takes care of BSR for you I think. I am being pushed towards using them and prolly will end up there. Just an FYI.
    -Bert
    Question Re: 16F1827 interrupt hosed
    I am seeing something strange.....It seems I can not read my ADC's or run anything in main when my interrupt is enabled. What my code is supposed to do is output a 1.5ms pulse every 16ms for "home" position on 4 servo's in the interrupt. At any time an ADC value on 5 ADC's is above a threshold I want to stop the interrupt and run the scaled up ADC values to run my servo's in real time. What am I missing?
        __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
        __config _CONFIG2, _PLLEN_OFF & _LVP_OFF & _LVP_OFF & _STVREN_OFF
    DEFINE OSC 8
     ;Define ADCIN parameters
      DEFINE ADC_BITS 8   ' Set number of bits in result
      DEFINE ADC_CLOCK 4   ' Set clock source, look on data sheet for chart
      DEFINE ADC_SAMPLEUS 500   ' Set sampling time in uS
      DEFINE  INTHAND myint                   ' Setup interrupt handler
    ; System hardware configuration
            OSCCON = %01110000   ' bit.7 =32MHz internal
            ANSELA = %00000001   ' all digital. A/D disabled
            ANSELB = %00000000
            TRISB =  %00000000    ' set port directions 0 = output, 1 = input
            TRISA =  %00000001
            ADCON0 = %00000111  ' Set PORTA digital 1, analog 0
            ADCON1 = %01000000
    ; Program variables
            ADCVAL      var     byte   bank0
            ADCVAL2     var     byte   bank0
            ADCVAL3     var     byte   bank0
            ADCVAL4     var     byte   bank0
            ADCVAL5     var     byte   bank0
    ; Program constants
            centM       con     1500        ;motor stop
            forM        con     2000        ;motor forward
            revM        con     1000        ;motor reverse
    ; Power on initialization to known port states
    PowerOn_init:
            PortA = 0             ' force low to avoid glitches
            POrtB = 0
            PIR1 = 0              ' clear TMR1 int flag
            PIE1 =   %00000001    ' TMR1 int enabled
            INTCON = %11000000    ' global & peripheral ints enabled
            T1CON =  %00010001    ' TMR1 1:2 prescale, timer1 on
     goto mainloop
    asm
    ; Save W, STATUS and PCLATH registers, if not done previously
    myint
            ; retfie auto-restores w, status, bsr, fsr and pclath
      BANKSEL T1CON
      clrf  BSR
      bcf   T1CON,TMR1ON ; stop timer 1
      bcf   PIR1,TMR1IF  ; clear over flow flag
      movlw 0xBF         ; load timer for 16,535 * 2 prescaler interrupt on 16 bit timer
      movwf TMR1H        ; load high byte
      movlw 0xFF
      movwf TMR1L        ; load low byte
      call  _home
      bsf   T1CON,TMR1ON ; re-enable timer 1
    ;  movlw 0x02
    ;  xorwf PORTB,f      ; toggle RB1
      retfie             ; Return from interrupt
    endasm
    home:
         if adcval < 4 and adcval2 < 4 and adcval3 <4 and adcval4 < 4 and adcval5 < 4 then
         PORTB = %00001111
           pauseus 1500
         PORTB = %00000000
    mainloop:
        call readADC
        call spin
    '    call forward
    '    call back
    '    call left
    '    call right
        pause 15
        goto mainloop
     readADC:
          adcin 0, adcval
          ADCIN 1, adcval2
          adcin 2, adcval3
          adcin 3, adcval4
          adcin 4, adcval5
     spin:
         if adcval > 4 then
           LATB = %00001111
                pauseus 6*(adcval) + 900
           LATB = %00000000
     forward:
         if adcval2 > 4 then
           LATB = %00001100
           LATB = %00000000
           LATB = %00000011
           LATB = %00000000
     back:
         if adcval3 > 4 then
           LATB = %00000011
           LATB = %00000000
           LATB = %00001100
           LATB = %00000000
     left:
         if adcval4 > 4 then
           LATB = %00000101
           LATB = %00000000
           LATB = %00001100
           LATB = %00001010
     right:
        if adcval5 > 4 then
           LATB = %00001010
           LATB = %00000000
           LATB = %00000101
           LATB = %00001010
    Try changing
    call readADC
    call spin
    to
    GOSUB readADC
    GOSUB spin
    From the manual:
    CALL
    CALL Label
    Execute the assembly language subroutine named Label.
    GOSUB is normally used to execute a PICBASIC PRO™ subroutine. The main difference between GOSUB and CALL is that with CALL, Label=s existence is not checked until assembly time. Using CALL, a Label in an assembly language section can be accessed that is otherwise inaccessible to PBP.
    See the section on assembly language programming for more information on CALL.
    CALL pass ' Execute assembly language subroutine named _pass
    Hello Dave,
    I changed the calls to subs and still nothing runs in main while the interrupt is enabled. I can't even get a simple portb.0 set / reset to give me anything on the I/O.
    Nick
    CALL or GOSUB doesn't make any difference.
    But you cannot run Basic Language statements in an Assembly Language interrupt.
    Re-use of PBP's system variables will corrupt the main programs flow.
    If you want to use Basic statements in ASM interrupts, you need to either use ON INTERRUPT or DT_INTS.
