I2C variable to LCD
Results 1 to 8 of 8
    Default Re: I2C variable to LCD
    As usual, post your whole code.
    We can only guess about the VAR num_of_beacons.
    Do you have something like;
    num_of_beacons[0] = $30+BVAR ' BVAR being the number you want to dispaly.
    Nov 2010
    Heres all the code:
    clear
    OSCCON.6 = 1          ' INTERNAL OSCILLATOR SELECT TO 4MHZ
    OSCCON.5 = 1          ' DURING MEPROG CONFIGURATION, USE
    OSCCON.4 = 0          ' OSCILLATOR INTIO2
    ' Define the USART registers
    DEFINE HSER_BAUD 9600 'Hser baud rate
    DEFINE HSER_CLROERR 1 'Hser clear overflow automatically
    DEFINE HSER_SPBRG 25  'Hser spbrg init
    DEFINE HSER_RCSTA 80h 'Hser receive status init
    DEFINE HSER_TXSTA 20h 'Hser transmit status init
    DEFINE HSER_BITS 8    'Use 8th bit for parit
    PAUSE 1000            ' PAUSE FOR A SECOND, WAITING FOR SYSTEM TO ENERGIZE
    ' INITIALIZE PORT E
    TRISE = %00000110      ; set PORTE
    ' INITIALIZE PORT D
    LATD =%00000000       ' CLEAR DATA LATCHES
    TRISD =%00001100      ' PORT D inputs/outputs
    ' INITIALIZE PORT C   CONTAINS TX FOR COMMUNICATION TO LCD SCREEN
    LATC =%00000000         ' CLEAR DATA LATCHES
    TRISC =%00000110        ; set all PORTC
    TXSTA =%00100000        ; SYNC = 0, TX ENABLED, BRGH = 0
    RCSTA =%10000000        ; TX/RX ENABLED
    BAUDCON.3 = 1           ; BRG16 = 1
    SPBRGH =%00000000       ; SPBRG = 25
    SPBRG =%00011001
    PIE1.4 = 0              ; DISABLE TX INTERRUPT
    SSPADD = $28             'I2C BRG
    SSPSTAT.7 = 1
    SSPCON1 = %00101000
    I2C_COMM VAR PORTC.4
    I2C_CLK VAR PORTC.3
    ADDR1 VAR BYTE
    CONT_SEND VAR WORD
    ADDR1 = $50
    ' INITIALIZE PORT B
    LATB =%00000000     'CLEAR DATA LATCHES
    TRISB =%00001011    'RB2 IS CANTX, RB3 IS CANRX
    INTCON2.7 = 1       'PORT B WEAK PULL UP DISABLE
    ' INITIALIZE PORT A
    LATA =%00000000       ' CLEAR DATA LATCHES
    TRISA =%11111111      ' PORT A ALL INPUTS
    ADCON1 =%00111111     'ALL DIGITAL I/O
    'PIN DEFINITION
    ALARM1 VAR LATD.4      ' PIN 27     GENERAL ALARM
    ALARM2 VAR LATD.5      ' PIN 28     BEACON ALARM
    ALARM3 VAR LATD.6      ' PIN 29     FLASHER FAIL ALARM
    ALARM4 VAR LATD.7      ' PIN 30     OPTIONAL OL ALARM
    ALARM5 VAR LATB.4      ' PIN 37      POL ALARM1
    ALARM6 VAR LATB.5      ' PIN 38     POL ALARM2
    ALARM7 VAR LATB.6      ' PIN 39     POL ALARM3
    ALARM8 VAR LATB.7      ' PIN 40     SPARE AT THE MOMENT (9/15/11)
    SYSTEM_OK VAR LATD.0    'PIN 19
    POL_ALARM_INPUT VAR PORTB.1 'PIN 34
    POL_ALARM_INPUT2 VAR PORTC.1 'PIN 16
    POL_ALARM_INPUT3 VAR PORTC.2 'PIN 17
    PPC_INPUT VAR PORTB.0   'PIN 33
    NUMBER_OUT VAR WORD
    DIP_A0 VAR PORTA.0     ' DIPS SWITCH ON PORTA FOR NUMBER OF BEACONS
    DIP_A1 VAR PORTA.1     ' DIP_AO WILL BE NUM_OF_BEACONS.Bit0
    DIP_A2 VAR PORTA.2     ' ....
    DIP_A3 VAR PORTA.3     ' DIP_A5 WILL BE NUM_OF_BEACONS.Bit5
    DIP_A4 VAR PORTA.4
    DIP_A5 VAR PORTA.5
    DIP_B1 VAR PORTE.1
    DIP_B2 VAR PORTE.2
    'VARIABLE
    WAIT_TIME VAR BYTE      ' TIME DELAY VARIABLE LOST BEACON
    X VAR BYTE              ' VARIABLE FOR ROLLING THROUGH BEACONS
    Y VAR BYTE              ' VARIABLE FOR ROLLING THROUGH ALARM CONFIGURATION
    NUM_OF_BEACONS VAR word[1]  ' VARIABLE TO HAVE NUMBER OF BEACON STORED INTO IT
    FLASH_STATE VAR BIT      ' VARIABLE TO STORE THE STATE OF THE FLASH
                             ' ON = 1      OFF = 0
    STATUS_CHANGE VAR BIT    ' VARIABLE BIT TO TELL THE CONTROLLER CHANGE HAS HAPPENED
    TEMP_RXB0SIDH VAR BYTE   ' TEMP BUFFER HIGH TO COMPARE THE REAL BUFFER TO
    TEMP_RXB0SIDL VAR BYTE   ' TEMP BUFFER LOW TO COMPARE THE REAL BUFFER TO
    LED_ALARM var bit[65]    ' CREATES 65 BITS, LABELED LED_ALARM[0-64]
    LOST_ALARM VAR BIT[65]   ' CREATES 65 BITS, LABELED LOST_ALARM[0-64]
    FF_ALARM VAR BIT[65]     ' CREATES 65 BITS, LABELED FF_ALARM[0-64]
    NORMAL_BEACON VAR BIT[65]  ' CREATES 65 BITS, LABELED NORMAL_BEACON[0-64]
    NUM_OF_POLS VAR word
    FFA_OK VAR BYTE
    LOST_OK VAR BYTE
    LED_OK VAR BYTE
    COMM_OK VAR BYTE
    HIGH ALARM1                   ' START ALL ALARMS OFF
    HIGH ALARM2
    HIGH ALARM3
    HIGH ALARM4
    low ALARM5
    LOW ALARM6
    LOW ALARM7
    LOW ALARM8
    '***************** BEGINNING OF ECAN CONFIGURATION******************
    CANCON=%10000000      ' Configuration Mode
    while CANSTAT !=$80   ' Wait until Canstat is in Config Mode
    PAUSE 10              ' Pause if not
    WEND                  ' proceed
    ECANCON =%00000000    ' Mode 0
    ' Baud Rate = 50bps @ 4 MHZ WITH 10 TQ
    BRGCON1 =$03
    BRGCON2 =$92
    BRGCON3 =$02
    ' Setting up Receive Mask 0 register
    RXM0SIDH =%10000000      ' 1'S IMPORTANT, 0'S WILL CHANGE
    RXM0SIDL =%11100000
    ' Setting up Receive Filter 0 register
    RXF0SIDH =%00000000      ' $004, STANDARD FOR BEACON TO CONTROLLER ID'S
    RXF0SIDL =%10000000      ' $00C, $014, $01C...
    CANCON=%00000000         ' NORMAL Mode
    while CANSTAT !=$00      ' Wait until Canstat is in NORMAL Mode
    WEND
    '***************** END OF ECAN CONFIGURATION******************
    'RECEIVE BUFFER 0 CONTROL REGISTER
    RXB0CON.6 = 0             ' MEANS BUFFER 0 ONLY RECEIVES STANDARD ID'S
    RXB0CON.5 = 1
    'TRANSMIT BUFFER 0 INITIATE, USED FOR CALLING OUT TO BEACON
    TXB0DLC =%00000001        ' LOAD DATA LENGTH, 1 BYTE
    TXB0D0 =%01110111         ' DATA IS $77, MEANING "BEACON CHECK IN"
    TXB0CON.0 = 1             ' LOW Priority
    TXB0CON.1 = 0
    'TRANSMIT BUFFER 1 INITIATE, USED TO SEND FLASHING SIGNAL
    TXB1DLC =%00000001        ' LOAD DATA LENGTH, 1 BYTE
    TXB1SIDH =%00000000       ' ID $000
    TXB1SIDL =%00000000       ' ALL BEACON WILL ACCEPT THIS ID
    TXB1CON.0 = 1             ' HIGHEST PRIORITY INSIDE CHIP
    TXB1CON.1 = 1
    'VARIABLE CONFIGURATION
    STATUS_CHANGE = 1               ' START WITH CHANGE, MAKES LCD SCREEN DISPLAY SOMETHING
    FLASH_STATE = 0                 ' BEACONS STARTS OFF
    TEMP_RXB0SIDH =%00000000        ' STARTING RECEIVE BUFFER ID $004
    TEMP_RXB0SIDL =%10000000        ' FIRST BEACON WILL SEND ID $00C
    'INITIATE NUM_OF_POLS
    IF DIP_B2 = 0 AND DIP_B1 = 0 THEN           'DIP SETTINGS FOR AMOUNT OF POLS
    NUM_OF_POLS = 0
    IF DIP_B2 = 0 AND DIP_B1 = 1 THEN
    NUM_OF_POLS = 1
    IF DIP_B2 = 1 AND DIP_B1 = 0 THEN
    NUM_OF_POLS = 2
    IF DIP_B2 = 1 AND DIP_B1 = 1 THEN
    NUM_OF_POLS = 3
    'INITIATE NUM_OF_BEACONS
    IF DIP_A0 = 0 THEN
    NUM_OF_BEACONS.BIT0 = 0
    NUM_OF_BEACONS.BIT0 = 1
    IF DIP_A1 = 0 THEN
    NUM_OF_BEACONS.BIT1 = 0
    NUM_OF_BEACONS.BIT1 = 1
    IF DIP_A2 = 0 THEN
    NUM_OF_BEACONS.BIT2 = 0
    NUM_OF_BEACONS.BIT2 = 1
    IF DIP_A3 = 0 THEN
    NUM_OF_BEACONS.BIT3 = 0
    NUM_OF_BEACONS.BIT3 = 1
    IF DIP_A4 = 0 THEN
    NUM_OF_BEACONS.BIT4 = 0
    NUM_OF_BEACONS.BIT4 = 1
    IF DIP_A5 = 0 THEN
    NUM_OF_BEACONS.BIT5 = 0
    NUM_OF_BEACONS.BIT5 = 1
    NUM_OF_BEACONS.BIT6 = 0
    NUM_OF_BEACONS.BIT7 = 0
    IF NUM_OF_BEACONS =%00000000 THEN
    NUM_OF_BEACONS = 64
    '**********************Read and clear RXBO*************************'
    'IF RXB0D0 = %00000000 THEN    ' SIMPLY READ THE BUFFER, it will flush itself
    'PAUSE 1                       ' DO NOTHING
    'ELSE
    'ENDIF
    '****************ALARM BIT CONFIGURATION************************
    Y = 1                      ' START AT FIRST BIT OF EACH ARRAY
    WHILE Y <= NUM_OF_BEACONS  ' ALL ALARMS FOR ALL BEACON MUST BE SET TO ZERO
    LED_ALARM[X] = 0           ' 0 IS NO ALARM, 1 IS AN ALARM CONDITION
    LOST_ALARM[Y] = 0
    FF_ALARM[Y] = 0
    NORMAL_BEACON[Y] = 1       ' NORMAL_BEACON = 1 IS GOOD, NORMAL_BEACON = 0
    Y = Y + 1                  ' MEANS THERE IS AN ALARM CONDITION
    WEND                       ' CONTINUE WHEN ALL BEACONS ARE ASSIGNED
    '*************INTERRUPT CONFIGURATION******************************
    INTCON =%10100000    ' ENABLE GLOBAL INTERRUPT
                         ' TIMER 0 INT ENABLED, FLAG LOW
    ON INTERRUPT GOTO INTAWHAT
    '**************TIMER0  CONFIGURATION
    T0CON =%00000100      ' TIMER 0, 16BITS, PRESCALE 1:32, TIMER0 IS OFF
    TMR0H =%10110000      ' CREATES .66 SECOND START TIME
    TMR0L =%10000000
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$52,$30]
    PAUSE 10
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$51]
    PAUSE 10
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$00,"Point Lighting Corp"]
    PAUSE 10
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$40,"Obstruction Lighting"]
    PAUSE 10
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$14,"     Controller"]
    PAUSE 10
    PAUSE 2000
    '$$$$$$$$$$$$$$$$$$$$$$$$____OPERATING CODE STARTS HERE_____$$$$$$$$$$$$$$$$$$
    RXB0CON.7 = 0             ' CLEAR RECEIVE BUFFER 0 FULL BIT
    T0CON.7 = 1               ' TURN ON TIMER0 JUST BEFORE MAIN PROGRAM
    START_CHECK:              ' STARTS THE BEACON CHECK SEQUENCE, first display info from last cycle
                               ' RETURN TO HERE AFTER ALL BEACON HAVE BEEN CHECKED
    TOGGLE SYSTEM_OK           'TOGGLE SYSTEM OK LED SO WE KNOW THE UNIT ISNT HUNG
    IF POL_ALARM_INPUT != 1 and POL_ALARM_INPUT2 != 1 and POL_ALARM_INPUT3 != 1 AND ALARM1 != 0 AND ALARM2 !=0 AND ALARM3 !=0 AND ALARM4 != 0  THEN
    HIGH alarm4                    'TURN OFF POL ALARM
    PAUSE 10
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$00,"System Operational"]
    PAUSE 10
    'I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$40,"Beacons: ",NUM_OF_BEACONS, " "]
    'PAUSE 10
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$40,"Beacons: "]
    PAUSE 10
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE, str num_of_beacons\1]
    PAUSE 10
    if num_of_polS >0 THEN
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$14,"Obst Lights (OL): ", NUM_OF_POLS]
    PAUSE 10
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$54,"Number of Alarms: 0"]
    PAUSE 10
    HSEROUT [DEC 6777]
    PAUSE 100
    HSEROUT [DEC 6888]
    IF POL_ALARM_INPUT = 1 OR POL_ALARM_INPUT2 = 1 OR POL_ALARM_INPUT3 = 1 THEN       ' CHECK POL ALARMS
    LOW ALARM4          'TURN ON POL ALARM
    LOW ALARM1          'TURN ON GENERAL ALARM
    goto DISPLAY_ERROR
    HIGH ALARM4
    LOW ALARM5
    LOW ALARM6
    LOW ALARM7                   'RESETING THE POL ARLARMS ON THE BOARD
    IF ALARM2 != 0 AND ALARM3 != 0 AND ALARM4 != 0 AND ALARM5 != 1 AND ALARM6 != 1 AND ALARM7 != 1 AND ALARM8 != 1 THEN
    HIGH ALARM1
    ENDIF             'RESETING GENERAL ALARM ONLY IF NO OTHER ALARMS ARE ACTIVE
    IF POL_ALARM_INPUT = 0 THEN       'POL 1 ALARM INPUT  RESET TO PLC
    HSEROUT [DEC 9981]
    PAUSE 50
    IF POL_ALARM_INPUT2 = 0 THEN    'POL 2 ALARM INPUT   RESET    TO PLC
    HSEROUT [DEC 9982]
    PAUSE 50
    IF POL_ALARM_INPUT3 = 0 THEN    'POL 3 ALARM INPUT RESET     TO PLC
    HSEROUT [DEC 9983]
    PAUSE 50
    TXB0SIDH =%00000000       ' ID $000, RETURN TO STARTING TRANSMIT BUFFER 1 ID'S
    TXB0SIDL =%00000000       ' ID LOW DOES NOT CHANGE
    TEMP_RXB0SIDH =%00000000   ' STARTING RECEIVE BUFFER ID $000, WILL ALWAYS BE
                               ' INCREMENTED TO $00C FOR FIRST BEACON
    X = 1                      ' STARTS AT FIRST BEACON
    NEXT_CHECK:
    WHILE X <= NUM_OF_BEACONS   ' WHILE X IS LESS THEN OR EQUAL TO NUMBER OF BEACONS
    TXB0SIDH = TXB0SIDH + 1            ' INCREMENT TX BUFFER TO NEXT BEACON ID
    TEMP_RXB0SIDH = TEMP_RXB0SIDH + 1  ' INCREMENT TEMP RX BUFFER TO NEXT BEACON ID
    TXB0CON.3 = 1                ' REQUEST TRANSMISSION ON BUFFER 0
    WAIT_TIME = 250              ' 250 X PAUSE 12 = 3 SECOND
    WHILE TEMP_RXB0SIDH != RXB0SIDH AND WAIT_TIME > 0 ' RECEIVE BUFFER 0 HAS A NEW MESSEGE FROM
        WAIT_TIME = WAIT_TIME - 1' DECREMENT COUNTER
        PAUSE 10                 ' 12 MILLISECOND PAUSE
    WEND
                                 ' 3.0 SECOND HAS EXPIRE AND NO RESPONSE
    if wait_time = 0 THEN
    GOTO LOST_BEACON             ' GOTO LOST BEACON
    READ_DATA0:   ' reads data from beacon
    if RXB0D0 !=%00000000 THEN   ' DATA INDICATES A BEACON NOT NORMAL
    GOSUB  BEACON_ALARM           ' GOTO LED ALARM SUBROUTINE
    ENDIF                        ' DATA0 WAS NORMAL (%00000000)
    IF RXB0D0 =%00000000 AND NORMAL_BEACON[X] = 0 THEN ' BEACON IS NORMAL ANS IT WASN'T BEFORE
    STATUS_CHANGE = 1          ' INDICATE THAT CHANGE HAS HAPPENED
    LOST_ALARM[X] = 0
    FF_ALARM[X] = 0
    NORMAL_BEACON[X] = 1       ' NORMAL_BEACON = 1 IS GOOD, NORMAL_BEACON = 0 BAD
    X = X + 1              ' INCREMENT COUNTER X
    GOTO NEXT_CHECK        ' CHECK NEXT BEACON X LESS THEN NUM_OF_BEACONS
    WEND                   ' CHECKED ALL BEACON, X = NUM_OF_BEACONS
                           ' NOW WE DISPLAY WHAT WE FOUND OUT FROM ALL THE BEACONS
    IF STATUS_CHANGE = 1 THEN     ' IF A CHANGE HAS OCCURED, LCD DISPLAY MUST CHANGE
    STATUS_CHANGE = 0             ' RESET STATUS_CHANGE BIT
    WHILE Y <= NUM_OF_BEACONS     ' SCROLLING THROUGH ALL ACTIVE BEACONS
    IF NORMAL_BEACON[Y] = 1 THEN  ' IF BEACON IS NORMAL
    if LOST_ALARM[Y] = 0 THEN     'CHECKING IF A BEACON IS LOST
    NUMBER_OUT = 1900 + Y
    HSEROUT [DEC4 NUMBER_OUT]        'TELLS THE PLC THAT THE BEACON HAS RECOVERED
    PAUSE 50
    if FF_ALARM[Y] = 0 THEN           'CHECKING FOR FLASHER FAILURE
    NUMBER_OUT = 2900 + Y
    HSEROUT [DEC4 NUMBER_OUT]          'TELLS THE PLC THE FF ERROR IS FIXED
    PAUSE 50
    Y = Y + 1                     ' INCREMENT Y TO TEST NEXT BEACON
    ELSE                  ' IF ONE BEACON IS NOT NORMAL
    GOTO DISPLAY_ERROR            ' GOTO DISPLAY ERROR
    WEND                          ' WILL ONLY ESCAPE WHILELOOP HERE IF ALL BEACON
    pause 5                       ' ARE NORMAL
    FFA_OK = 67
    LOST_OK = 67
    LED_OK = 67
    LOOKDOWN2 FF_ALARM, [1], FFA_OK                      'CHECKING TO SEE IF THE VALUE 1
    LOOKDOWN2 LOST_ALARM, [1], LOST_OK                    'IS STORED IN THE ERROR LOCATIONS
    LOOKDOWN2 LED_ALARM, [1], LED_OK
                                                           'IF THERE IS NO "1" THEN THERES NO ERROR
    IF FFA_OK = 67 AND LOST_OK = 67 AND LED_OK = 67 THEN                    'SO WE CAN RESET THE ALARMS
    HIGH ALARM3
    HIGH ALARM1
    HIGH ALARM2
    IF FFA_OK = 67 AND LOST_OK = 67 AND LED_OK != 67 THEN                        'IF THE COMM AND FF ARE OK,
    HIGH ALARM3        'BUT THE LED IS STILL OUT,
    HIGH ALARM1        ' THEN WE CANT RESET THEM
    'HIGH ALARM2   NOT INCLUDED HERE                                              'ALL. ALARM2 (BEACON) IS LEFT OUT OF THE RESET
    GOTO START_CHECK
    DISPLAY_ERROR:
    IF LED_ALARM[Y] = 1 THEN        'CHECKING LED ARRAYS
    LOW  ALARM2                    'TURN ON BEACON ALARM
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$51]         ' ALWAYS $FE, $51 = CLEAR SCREEN
    'HSEROUT [$FE,$45,$00,"System Error"] '$45 cursor position, $00 top left
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$00,"Beacon: ", str y\2," " ]
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$40,"LED Failure"]
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$14,"____________________"] '$45 cursor position,
    IF NUM_OF_POLS > 0 THEN
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$54,"Beacons: ", str NUM_OF_BEACONS\2," ","OLs: ",  str NUM_OF_POLS\2]
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$54,"Beacons: ", str NUM_OF_BEACONS\2," "]
    PAUSE 50
    NUMBER_OUT = 3000 + Y
    PAUSE 100
    if LOST_ALARM[Y] = 1 THEN     'CHECKING IF A BEACON IS LOST
    LOW ALARM3                      'TURN ON FFA ALARM
    'I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$00,"System Error"] '$45 cursor position, $00 top left
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$40,"Lost Beacon"]
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$54,"Total Beacons: ", str NUM_OF_BEACONS\2," "]
    NUMBER_OUT = 1000 + Y
    PAUSE 100
    ELSEif LOST_ALARM[Y] = 0 THEN     'CHECKING IF A BEACON IS LOST
    PAUSE 100
    if FF_ALARM[Y] = 1 THEN           'CHECKING FOR FLASHER FAILURE
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$00,"Beacon: ",str y\2," " ]
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$40,"Flasher Failure"]
    NUMBER_OUT = 2000 + Y
    PAUSE 100
    ELSEif FF_ALARM[Y] = 0 THEN           'CHECKING FOR FLASHER FAILURE
    PAUSE 100
    Y = Y + 1                  ' NEXT BEACON
    ENDIF                      ' ENDIF OF (IF STATUS_CHANGE = 1)
    IF POL_ALARM_INPUT = 1 THEN       ' CHECK POL ALARM 1
    HIGH ALARM5
    STATUS_CHANGE = 1
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$00,"POL Alarm: Level 1"] '$45 cursor position,
    PAUSE 100
    HSEROUT [DEC 9991]
    LOW ALARM5
    IF POL_ALARM_INPUT2 = 1 THEN            'CHECK POL ALARM 2
    HIGH ALARM6
    STATUS_CHANGE = 1
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$00,"POL Alarm: Level 2"] '$45 cursor position, $00 top left
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$54,"Beacons: ",str NUM_OF_BEACONS\2," ","OLs: ",  str NUM_OF_POLS\2]
    PAUSE 100
    HSEROUT [DEC 9992]
    LOW ALARM6
    IF POL_ALARM_INPUT3 = 1 THEN       'CHECK POL ALARM 3
    HIGH ALARM7
    STATUS_CHANGE = 1
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$00,"POL Alarm: Level 3"] '$45 cursor position, $00 top left
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$54,"Beacons: ",str NUM_OF_BEACONS\2," ","OLs: ",str  NUM_OF_POLS\2]
    PAUSE 100
    HSEROUT [DEC 9993]
    PAUSE 100
    LOW ALARM7
    GOTO START_CHECK
    BEACON_ALARM:           ' ALL ALARM MESSEGES GO TO THIS LOCATION, MUST FILTER
                            ' ALARM AND SET ALARM BIT TO 1 OF FAILED BEACON
    IF RXB0D0 = %00001111 and RXB0DLC = %00000010 THEN' DATA0 ID $0F FOR LED ALARM ON BEACON
    STATUS_CHANGE = 1               ' CHANGE HAS HAPPENED
    NORMAL_BEACON[X] = 0            ' NORMAL BIT OFF
    LED_ALARM[X] = 1                ' LED ALARM BIT ON
    IF RXB0D0 = %11111111 THEN      ' DATA0 ID FOR FLASHER FAIL ON BEACON
    FF_ALARM[X] = 1                 ' FF ALARM BIT ON
    RETURN                          ' RETURN BACK TO CODE AFTER BITS ARE ASSIGNED
    LOST_BEACON:                    ' LOST BEACON COME HERE
    LOST_ALARM[X] = 1               ' LOST ALARM BIT ON
    GOTO NEXT_CHECK                 ' GOTO NEXT CHECK, NO DATA0 TO READ
    '***************************INTERRUPT BEGINS**********************************
    DISABLE                      ' MUST DISABLE BEFORE INTERRUPT ROUTINE IS USED
    INTAWHAT:                    ' INTERRUPT HAS OCCURRED
    TOGGLE SYSTEM_OK
    T0CON.7 = 0                  ' STOP TIMER WHILE EVERYTHING IS RESET
    IF FLASH_STATE = 1 THEN      ' IF BEACONS WERE ON
    FLASH_STATE = 0              ' TURN FLASH_STATE BIT LOW FOR NEXT CYCLE
    TXB1D0 =%00000000            ' DATA IS $00, MEANING "FLASHING OFF"
    TXB1CON.3 = 1                ' REQUEST TRANSMISSION ON BUFFER 1
    WHILE TXB1CON.3 != 0         ' HAS IT TRANSMITTED
    if COMSTAT.0 = 1 THEN        ' TX ERROR WARNING OR RX ERROR WARNING
    'comm error code here           'PROGRAM LOOPS HERE UNTIL COMM IS GOOD
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$00,"Communcation Error"] '$45 cursor position, $00 top left
    I2CWRITE I2C_COMM, I2C_CLK, CONT_SEND, ADDR1, [$FE,$45,$40,"Flasher Failure"] '$45 cursor position, $40 second row
    HSEROUT [DEC 7777]
    hserout [dec 8888]
    STATUS_CHANGE = 1
    PAUSE 1000                     ' PAUSE 1000 MS WHILE WAITING
    PAUSE 10                     ' PAUSE 10 MS WHILE WAITING
    WEND                         ' TRANSMITTION SUCCESSFUL
    INTCON.2 = 0                 ' RESET TIMER0 INT FLAG
    TMR0H =%10110000             ' CREATES .66 SECOND BETWEEN NEXT INTERRUPT
    TMR0L =%10000000
    ELSEif flash_state = 0 then      ' ELSE BEACONS WERE OFF
    FLASH_STATE = 1              ' TURN FLASH_STATE BIT HIGH FOR NEXT CYCLE
    TXB1D0 =%11111111            ' DATA IS $FF, MEANING "FLASHING ON"
    HSEROUT [DEC 7777]
    hserout [dec 8888]
    STATUS_CHANGE = 1
    TMR0H =%00001010             ' CREATES 2 SECOND BETWEEN NEXT INTERRUPT
    TMR0L =%00000000
    T0CON.7 = 1                  ' START TIMER
    RESUME                       ' GO BACK TO WHERE CODE WAS INTERRUPTED
    ENABLE                       ' MUST USE ENABLE
    end                          ' MUST END WITH END
    Nov 2010
    Looks like I got it working after adding the $30 to the value. I couldn't find anything in the help about having to add the $30, what is the reason for it?
    Nov 2010
    Looks like I spoke too soon. It seems to display numbers up to 3 fine, then freaks out. I have up to 64 beacons, how can I make this work?
    Nov 2010
    Got it working, the screen needed the HEX characters, and I was trying to send it DECIMAL. A bit more code required, but problem solved.
    Aug 2010
    Maryland, USA
    Glad we could help -LOl. Really nice you got it going
    -Bert
    The 30 + x is an ASCII string thing.
