Problem with bits in byte array....
Results 1 to 16 of 16
    Default Re: Problem with bits in byte array....
    Thanks, but the section covering arrays in the manual says:
    On PIC18 devices, byte, word and long-sized arrays are only limited in length by the amount of available memory. The compiler will assure that arrays, as well as
    simple variables, will fit in memory before successfully compiling.
    My example allocates 265 bytes and one bit, add to that the PBP system vars. It should easily fit in the 1536bytes in the 18F25K20, which is what I'm using by the way, and I'm not getting any errors or warnings.
    My "index-pointers" are WORD sized (becauae I have 256*8=2048 bits in the array) but currently it looks like I can't index bits beyond the 32'nd byte (ie when the index pointer is >255). I haven't seen anyone mention this limitation so I'm not saying this is the case (and I really hope it's not) but currently it's the only thing I can think of.
    Thanks!
    OK,
     Buffer.0[Putbit] = Temp
    should it be Buffer.0(Putbit) = Temp
    [, vs (
    Thanks Don,
    No, both [] and () should work as far as I know. I tried and it didn't make a difference.
    The problem definitely is in the bit-indexing not allowing me to index above 255....
    Take a look at this example:
    Buffer VAR BYTE[256]
    Index VAR WORD
    CLEAR
    HSEROUT["Buffer[32]: ", DEC Buffer[32],13]
    Buffer.0[256] = 1        ' Set LSB of Buffer[32]
    Index = 256
    Buffer.0[Index] = 0     ' Clear LSB of Buffer[32]
    Pause 100
    It gives the following results:
    As you can see, direct/literal indexing the 256'th bit works but doing it thru a variable doesn't. In Melanies example (which may be in error) she states that it should be possible to index bits above 255 this way (as long as the indexing variables is WORD, which it is in my case).
    I have no problem index bytes (as bytes) above 255, it's just this bit-indexing that is screwing with me.
    Henrik, thankyou too for explanation.
    A little different approach...........
    1, take 3 bytes at a time (from low array) and place into a LONG, lower 3 bytes, (zero high byte)
    2, left-shift 6 bits, (puts next 6 bits alone in highbyte) place highbyte into array 1/2 way up, clear highbyte, shift again.........
    for a total of 4 times (unpacks 3 base64 packed bytes to 4 bytes as you layed out)
    3, load next 3 bytes to long etc........................up to end
    not sure about padding at the part to have the correct unpacked string.
    Don
    Hi Don,
    Thank you but I'm doing my very best to avoid LONGs, the code produced by the long version of the compiler is much bigger than the normal even if you're not actually using a single LONG variable. So, I will do my very best to avoid using LONGs as LONG as I can ;-)
    It's not that it can't be done in another way, I had just settled on this and it had me cornered for a while. Now I know what the problem is and I'll aproach it from another angle. Had I bothered to look further back in the manual than the section on arrays I would've found this:
    7.6.4 Accessing Arrays as Multiple Variable-Types
    It is possible for a single array to be declared with multiple names and for each name to be assigned a different variable type. Note that offset for BITs are limited to a maximum value of 255
    To me, that statement is a little vague... I'm indexing a BYTE-array but on a bit basis so the above may apply (apparently) but it DOES work when "manually" indexing it:
    Buffer VAR BYTE[64]
    Index VAR WORD
    Index=256
    Buffer.0[256] = 1  'Works
    Buffer.0[Index] = 0  ' Doesn't work
    Time to rethink this.
    OK then, good info,
    I know you can create any of this, but trying to be helpfull,
    THIS.....
    -manipulates 2 words to unpack (thats what VB calls it)
    3 bytes from low array to 4 bytes of 6 bit each in
    other array , needs indexing to move to next 3 and 4 locations
    -The mid byte of the 24 bit Base64 is in W1 and W2 since it is used in destination byte 2 and 3
    -only 140 bytes as is to do 24bit at a time.
    arr1 var byte[8]   'base64 packed array or part of array
    arr2 var byte[12]  ' array to unpack into
    w1 var word
    w2 var word
    w1= arr1[1]
    w2= arr1[2]
    w1= w1 >> 2
    arr2[1]=w1.byte0 & 63
    w1=w1 >> 2
    arr2[2]= w1.byte1 & 63
    arr2[4]=w2.byte1 & 63
    w2=w2 << 2
    arr2[3]= w2.byte0 & 63
    Don
    Thank you Don,
    Your help is much appreciated, I hope it doesn't look or feel that it's not!
    I'll give that code a try as it does look tighter than the one I'm currently trying in my effort to avoid the bit-indexing.
