Hi Don,
Thank you but I'm doing my very best to avoid LONGs, the code produced by the long version of the compiler is much bigger than the normal even if you're not actually using a single LONG variable. So, I will do my very best to avoid using LONGs as LONG as I can ;-)
It's not that it can't be done in another way, I had just settled on this and it had me cornered for a while. Now I know what the problem is and I'll aproach it from another angle. Had I bothered to look further back in the manual than the section on arrays I would've found this:
7.6.4 Accessing Arrays as Multiple Variable-Types
It is possible for a single array to be declared with multiple names and for each name to be assigned a different variable type. Note that offset for BITs are limited to a maximum value of 255
To me, that statement is a little vague... I'm indexing a BYTE-array but on a bit basis so the above may apply (apparently) but it DOES work when "manually" indexing it:
Buffer VAR BYTE[64]
Index VAR WORD
Index=256
Buffer.0[256] = 1 'Works
Buffer.0[Index] = 0 ' Doesn't work
Time to rethink this.
