hello
i want to write a code in high memory of pic18f4550 so i modified the pbppic18.lib file and changed ORG RESET_ORG + 8 to ORG 27040 as explained in this post: http://www.picbasic.co.uk/forum/show...4622#post24622
now i created a simple program as below, it worked and i am able to write this code in high memory of 18f4550 starting from 27040(69A0H)
however the below code does not care about DEFINE LOADER_USED 1 parameter and i am unable to program it on my defined location.Code:define LOADER_USED 1 DEFINE OSC 48 adcon1 = 15 @GOTO 0x0040
can any one tell me why the first program is considering the define LOADER_USED 1 parameter and the second one is ignoring it.Code:define LOADER_USED 1 DEFINE OSC 48 adcon1 = 15 ;--- Setup Interrupts ------------------------------------------------------ INCLUDE "DT_INTS-18.bas" ; Base Interrupt System ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler USB_Handler endm INT_CREATE ; Creates the interrupt processor endasm ;--- Setup USB ------------------------------------------------------------- INCLUDE "DT_HID260.pbp" DEFINE USB_VENDORID 6017 DEFINE USB_PRODUCTID 2000 DEFINE USB_VERSION 1 DEFINE USB_VENDORNAME "TEST DEVICE" DEFINE USB_PRODUCTNAME "TEST DEIVCE" DEFINE USB_SERIAL "001" DEFINE USB_INSIZE 64;32 ; IN report is PIC to PC (8,16,32,64) DEFINE USB_OUTSIZE 64;16 ; OUT report is PC to PIC DEFINE USB_POLLIN 10 ; Polling times in mS, MIN=1 MAX=10 DEFINE USB_POLLOUT 10 ; --- Each USB LED is optional, comment them if not used ---- DEFINE USB_LEDPOLARITY 1 ; LED ON State [0 or 1] (default = 1) DEFINE USB_PLUGGEDLED PORTB,0 ; LED indicates if USB is connected DEFINE USB_TXLED PORTC,2 ; " " data being sent to PC DEFINE USB_RXLED PORTC,1 ; " " data being received from PC main: @ ON_USBRX_GOSUB _HandleRX pause 10 goto main HandleRX: if USBRXBuffer[1] == "S" then @GOTO 0x0040 else ARRAYWRITE USBTXBuffer,[STR USBRXBuffer\USBBufferSizeRX] GOSUB DoUSBOut endif return
thanks
