Serial Data Recorder
Results 1 to 3 of 3
    d1camero's Avatar
    d1camero Guest
    Default Serial Data Recorder
    I want to build a "portable" firmware serial recorder which will record RS232 data to memory, then play it back at a later point in time. (to capture voltage readings from a serial DMM). I figure I can use a real small PIC, like a 12F675, but I am not sure what to use for memory. Is there an easy to use, inexpensive, solid state memory I can use with a PIC for this?
    It would be real nice if I could leverage a USB memory stick, but I think that USB may be too complicated.
    thanks
    Don
    FRAM... not the cheapest but the simplest.
    Feb 2004
    Germany
    Don,
    since you are picking up data packets from a DMM I guess there is not that much Data.
    A serial EEPROM (I2C) would be an inexpensive way and is easy to handle with PBP.
    You should consider to add an RTC (like DS1307)
    to timestamp you log entries.
    RAMTRON have solutions (FRAM+RTC) on a a single chip.
    regards
    Ralph
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
