PWM to Frequency
Results 1 to 4 of 4
    Sep 2005
    Campbell, CA
    Default Re: PWM to Frequency
    How you go about this depends a lot on the resolution you need. Do you have some idea of that?
    Charles Linquist
    Aug 2010
    Maryland, USA
    Also, will the pic be deticated to this or are you going to want/need other things frm it also.
    -Bert
    The PIC is dedicated to doing this alone, nothing else.
    As far as resolution, the more the better of course. I just don't know how much I can bullshit the controller until I hook it up.
    I am playing around with the PULSIN for the incoming PWM and HPWM for the outgoing signal. It seems to be working pretty good.
    Here is the code.
    Include "modedefs.bas"    ' Mode definitions for Serout
    Yellow          Var     PortC.5
    Red             Var     PortC.4
    Green           Var     PortC.3
    Rate            var     PortC.1
    LCD             var     PortB.5
    VoltIn          var     word
    Flasher         var     word
    Speed           var     word
    Numerator       var     word
    Divisor         var     word
    Total           var     word
    Prefix          con     $FE             ' needed before each command
    LcdCls          CON     $51             ' clear LCD (use PAUSE 5 after)
    CursorPS        con     $45             'Cursor Position
    Backlight       con     $53             ' Backlighting 1-8
    TRISC = 0000010
    TRISB=000000
    TRISB=111111
    Option_Reg.7=0    'Pull-Ups Enabled
    ANSELH=0          'PortB Digital
    WPUB.0=1
    WPUB.1=1
    WPUB.2=1
    WPUB.3=1
    WPUB.4=1
    INTCON.7=0
    Flasher = 0
    define OSC 4
    'OSCCON.6=1'0    '250khz
    'OSCCON.5=0    '250khz
    'OSCCON.4=0'0    '250khzHZ
    pause 10
    SEROUT2 LCD,84, [Prefix,Backlight,8] 'LCD used for debug purpose
    Serout2 LCD, 84, [Prefix,LcdCLS]
    pause 10
    SEROUT2 LCD,84, [Prefix,CursorPS,0, "RPM Simulator "]
    high green
    high red
    high yellow
    Repeat
      GOSUB ON_Off
      Flasher = Flasher + 1
    UNTIL Flasher = 5
    Flasher = 0
    '245 to 24000 for frequency out in the HPWM  23755 range
    '15.3HZ to 1.52kHZ at the 1/16 flip flop output
    Start:
      gosub Get_Pulse
      Gosub Math
    Goto Start
    Get_Pulse:
      Pulsin Rate,0,Numerator
      pulsin Rate,1,Divisor
      Total=Numerator+Divisor
      If Total=0 then 'LED Green when PWM present, red when no PWM
         HIgh Yellow
         Low Red
         High Green
         HIgh Yellow
         High Red
         Low Green
    Math:
      SEROUT2 LCD,84, [Prefix,CursorPS,0, dec5 Numerator," ",dec5 Divisor, " ", dec5 Total]
      Divisor=Divisor/10
      Speed = (240*Divisor)
      SEROUT2 LCD,84, [Prefix,CursorPS,64, dec5 Speed]
      HPWM 1,127,Speed
    '___________________________________________
    '-----------Activate/Deactivate Outputs-----
    On_Off:
      high REd
      high Green
      high Yellow
      PAUSE 100
      high REd
      low Green
      high Yellow
      PAUSE 100
