Power factor measurement
Results 1 to 21 of 21
    Default Re: Power factor measurement
    I've seen a PC based utility that does this with an interseting approach; it uses the 2 sound card channels to track the voltage and current readings, does the math and displays all the parameters on the screen. The simple coupling hardware is also described in the help section. The company's since changed its name so it took some searching, but here it is. http://www.infinitespectra.com/freew...400/index.html
    Since you can calibrate the software for your own setup, I'm sure the components arent too critical either.
    And did I mention its free?!
    Anand
    Dec 2005
    Neat!
    If you do this, make sure you use an isolation transformer between AC line and your test circuitry. Otherwise, you caan make the case of your PC hot.
    Dave, the circuit does isolate both the channels already, doesnt it? The voltage sensing is by way of a 12 volt step-down, and the current sense is a coil wound around one of the power carrying cables. This might be the only difficult to procure component for those having no access to Digikey, but since there is an option to calibrate the unit, I suspect a home made hand wound coil should be fine.
    Dec 2005
    Anand, sorry - I didn't look at the circuit. The transformer is fine.
    Moved from Schematics.
