I have a pic connected through a RS232 and the transmit seems to be working fine but I am having issues with sending the pic commands(at least its not doing what I want it to).
When the pic powers up, I get the "I am online." message.Code::SetTxRx ' Set receive register to receiver enabled DEFINE HSER_RCSTA 90h ' Set transmit register to transmitter enabled DEFINE HSER_TXSTA 20h ' Set baud rate DEFINE HSER_BAUD 2400 ' Set SPBRG directly (normally set by HSER_BAUD) DEFINE HSER_SPBRG 25 ' Use only if even parity desired 'DEFINE HSER_EVEN 1 :SendOnline HSEROUT ["I am online.", 10, 13] :Online High Porta.6 :Listen HSerin [INC] HSerout ["You entered: ", INC, 10, 13] IF INC = 1 THEN Think IF INC = 2 THEN TURNON IF INC = 3 THEN TURNOFF GOTO Listen :TURNON HIGH Porta.7 GOTO Listen :TURNOFF LOW Porta.7 GOTO Listen
When I send a 1 the pic responds properly with the "You entered: 1" back.
Same with 2 and whatever number I send.
The issue is that It is not running the IF commands.
I also want to make the incoming data a bit longer such as A123. When I try that, I get:
You entered: A
You entered: 1
You entered: 2
and so on.
Any help would be great.
