HSerin
Results 1 to 4 of 4
Thread: HSerin
    Jan 2010
    Default HSerin
    I have a pic connected through a RS232 and the transmit seems to be working fine but I am having issues with sending the pic commands(at least its not doing what I want it to).
    :SetTxRx                ' Set receive register to receiver enabled
    	DEFINE HSER_RCSTA	90h
    	' Set transmit register to transmitter enabled
    	DEFINE HSER_TXSTA	20h
    	' Set baud rate
    	DEFINE HSER_BAUD	2400
    	' Set SPBRG directly (normally set by HSER_BAUD)
    	DEFINE HSER_SPBRG	25
                    ' Use only if even parity desired
    	'DEFINE HSER_EVEN	1
    :SendOnline
    	HSEROUT ["I am online.", 10, 13]
    :Online
    High Porta.6
    :Listen
    HSerin [INC]
    HSerout ["You entered: ", INC, 10, 13]
    IF INC = 1 THEN Think
    IF INC = 2 THEN TURNON
    IF INC = 3 THEN TURNOFF
    GOTO Listen
    :TURNON
    HIGH Porta.7
    GOTO Listen
    :TURNOFF
    LOW Porta.7
    GOTO Listen
    When the pic powers up, I get the "I am online." message.
    When I send a 1 the pic responds properly with the "You entered: 1" back.
    Same with 2 and whatever number I send.
    The issue is that It is not running the IF commands.
    I also want to make the incoming data a bit longer such as A123. When I try that, I get:
    You entered: A
    You entered: 1
    You entered: 2
    and so on.
    Any help would be great.
    Jan 2010
    Default Re: HSerin
    Anther issue I am having is that the pic will hang up after sending data now and then. It almost always hangs if I send something like 12345.
    Jan 2010
    Default Re: HSerin
    Hserin [DEC3 INC]
    IF INC = 111 THEN GOTO Think
    IF INC = 222 THEN GOTO TURNON
    IF INC = 333 THEN GOTO TURNOFF
    This worked great. However, it is sending odd chars back. Am I formatting the HSerout wrong?
    Default Re: HSerin
    Maybe?
    HSerout ["You entered: ",DEC INC, 10, 13]
