MikroBasic to PBP Pro: Boost mode SMPS
Results 1 to 29 of 29
    Feb 2004
    Michigan, USA
    Default Re: MikroBasic to PBP Pro: Boost mode SMPS
    That is very true. I added a pause of 50mS in each button press if-endif routine.
    The problem with that is the LED's flicker each time the button is pressed. Not sure why the pause should effect the PWM. I thought that the PWM was continuous unless you turned it off with CCP1CON = 0. That was my basic understanding anyway and the theory behind the idea. Run pwm continuously and vary the duty cycle based on a target current limit and the actual feedback results. Add or subtract by one the duty cycle number until the current limit is achieved.
    Also the LED's flicker when ever there is a WRITE command so I created a counter that only writes the value every 25000 cycles.
    Even with 25000 cycles EEPROM will wear out relative soon.
    About the button,maybe you can try to wait for the button release before proceed.
    Also the the idea of add or subtract one to the duty cycle in theory it will work, practically will have a lot of jitter. Here PID control may help (more complicate though).
    Feb 2004
    Michigan, USA
    I'd be willing to learn about PID's. It's something I wanted to do anyway. Have you worked with them Ioannis?
    For something similar to what you try, but not succesfully. It just oscilated and could not fix it.
    I will try again, but am busy right now.
    Feb 2004
    Michigan, USA
    After some tweaking I have this pretty much working now. I can get it to ramp up slowly to full brightness, maintain a set level, be adjusted up and down, have the new value write to EEPROM and next time it is powered up it will ramp up to the last saved level. All I want to add now is ramp down at power off. Not a problem.
    I'd like to reduce code size though. I have a lot of IF THEN's and a lot of FOR NEXT's. They are used to increment and decrement a byte value based on which level output is set.
     rampup:l = 0
    for l = 0 to led
    if L = 0 then
    fb = 0
    CCP1CON = 0
    ramp = 0
    portc.2 = 0
    IF L = 1 then
    fb = 10
    if L = 2 then
    fb = 45
    if L = 3 then
    pause 25
    fb = 90
    if L = 4 then
    pause 40
    fb = 130
    IF L = 5 then
    pause 50
    fb = 170
    if L = 6 then
    pause 75
    fb = 280
    if L = 7 then
    fb = 450
    adcin 1, temp
    If temp > fb and L > 0 then
    ramp = ramp - 1
    IF ramp <= 0 then
    CCP1CON = 0
    ramp = 0
    portc.2 = 0
    If temp < fb Then
    ramp = ramp + 1
    If ramp >= 40 then
    ramp = 40
    If ramp > 41 then
    ramp = 0
    CCP1CON = 111100
    PR2 = 44
    high_duty=(ramp>>2)        'high 6 bits in CCPR1L
          low_duty=(ramp<<6)         'low two bits for CCP1CON
          low_duty=(low_duty>>2)           'shift back to CCP1CON<5:4>
          low_duty.3=1                     'PWM configuration bit
          low_duty.2=1                     'PWM configuration bit
    CCPR1L=high_duty
    CCP1CON = $0C
    T2CON = 4
    next l
    This is the ramp up routine that seems to work well. The ramp down is similar. Any way to reduce this block of code in size?
