MikroBasic to PBP Pro: Boost mode SMPS
Results 1 to 29 of 29
    Feb 2004
    Michigan, USA
    Default MikroBasic to PBP Pro: Boost mode SMPS
    Hi group,
    I found an instructables article on creating a boost mode power supply based on a PIC. Its programmed in MikroBasic so I thought Id try and convert it to PBP PRO.
    There are a couple of questions I have and a few issues. I'd also like to add the ability to have pushbutton up and down dimming and soft start/soft stop too.
    Anyway, here is the original program:
    dim temp as word
    dim final_period, final_duty, high_duty, low_duty, last_adjust as byte
    dim  supply_multiplier, period_multiplier as float
    dim v_feedback, v_supply, t_rise, SMPS_duty, t_period, SMPS_period as float
    dim EE_pointer, EE_data as byte
    'set values
    const v_ref as float=3.8               'float  5.1 in the example
    const supply_ratio as float=11.35      'float
    const osc_freq as float=8              'integer or float
    const L_Ipeak as float=67             'float
    const fb_value as word=443             'word   225 in the example
    sub procedure PRE_CALC
    'precalculations
      supply_multiplier=v_ref*supply_ratio
      period_multiplier=(4/osc_freq)
    end sub
    sub procedure UPDATE_SMPS
    'take Vss reading
          temp=0
          temp=ADC_read(ANS0) ' ADC conversion
    'convert to voltage
          v_feedback=temp                 'put ADC in float
          v_supply=v_feedback/1024        'find supply % of vref
          v_supply=v_supply*supply_multiplier  'find supply volts
    'calculate rise time
          t_rise=L_Ipeak/v_supply                'find rise time @ supply volts for L/Ipeak
    'calculate CCPR1L:CCP1CON<5:4>
          SMPS_duty=t_rise*osc_freq        'find duty cycle value
          final_duty=SMPS_duty             'convert to byte
    'calculate period
          t_period=(t_rise*1.33)           'dutycycle = .75period
    'calculate PR2
          SMPS_period=(t_period/period_multiplier)  'find period value
          final_period=SMPS_period-1.0              'put in byte
    'put in register masks
          high_duty=(final_duty>>2)        'high 6 bits in CCPR1L
          low_duty=(final_duty<<6)         'low two bits for CCP1CON
          low_duty=(low_duty>>2)           'shift back to CCP1CON<5:4>
          low_duty.3=1                     'PWM configuration bit
          low_duty.2=1                     'PWM configuration bit
    'LOG TO EEPROM
       'only write if we measure somthing,
       'prevents false writes durring programming b/c MCLR is disabled
       if temp > 0 then
          EE_data=word(temp>>8) 'high 8 bits first address
          Eeprom_Write(EE_pointer, EE_data)
          EE_pointer=EE_pointer+1
          EE_data=temp      'low 8 bit second address
          'put final_duty in eeprom
          Eeprom_Write(EE_pointer, final_duty)
          'put final_period in eeprom
          Eeprom_Write(EE_pointer, final_period)
          'reset write pointer if needed
          if EE_pointer > 197 then EE_pointer=1 end if
         'update the write pointer
          Eeprom_write(0, EE_pointer)
       end if
    end sub
    'set ADC
      GPIO = 0
      CMCON0 = 7
      TRISIO = 0              ' designate gpio as output
      TRISIO.ANS0 = 1         ' pin ANS0 as input  (Supply feedback)
      TRISIO.ANS1 = 1         ' pin ANS1 as input (HV-feedback)
      ANSEL.ANS1=1
      ANSEL.ANS0=1
      ADCON0.VCFG = 0         ' Vdd as Vref
    'Low Voltage Indicator Light
      GPIO.4=1 'indicator light on
    'delay and take Vss reading
      EE_pointer=Eeprom_read(0)
      delay_ms(1000)
      PRE_CALC
      UPDATE_SMPS
    'setup PWM
      PR2=final_period 'sets PWM frequency
      CCPR1L=0    '8 most sig. duty cycle bits =0
      CCP1CON.5=0 'least significant bits = 0
      CCP1CON.4=0 'least significant bits = 0
      CCP1CON=12  'turns on PWM (set CCP1CON=0 at any time to turn off PWM)
      T2CON=4     'turns on TIMER2 module (required for PWM timing)
      last_adjust=0
    while true
          temp=0
          temp=ADC_read(ANS1) ' ADC conversion
          if temp > fb_value then   'feed back OVER set voltage
             if last_adjust=1 then 'if 0 then already off
                CCPR1L=0
                CCP1CON.5=0
                CCP1CON.4=0
                GPIO.5=1
                GPIO.4=0
                last_adjust=0
             end if
             if last_adjust=0 then
                CCPR1L=high_duty
                CCP1CON=low_duty
                GPIO.5=0
                GPIO.4=1
                last_adjust=1
             end if
          end if
    wend
    end.
    And here is my PBP PRO conversion so far:
    define OSC 48temp VAR word
    final_period var byte
    final_duty var byte
    high_duty var byte
    low_duty var byte
    last_adjust var byte
    supply_multiplier  var word 'as float
    period_multiplier var word 'as float
    v_feedback var word
    v_supply var word
    t_rise var word
    SMPS_duty var word
    t_period var word
    SMPS_period var word
    EE_pointer var byte
    EE_data var byte
    v_ref var byte
    supply_ratio var byte
    osc_freq var byte
    L_Ipeak var byte
    fb_value var word
    'set values
    v_ref = 38/10              'float  5.1 in the example, 3.8 here
    supply_ratio = 1135/100    'float, 11.35 here
    osc_freq = 8               'integer or float
    L_Ipeak = 67               'float
    fb_value = 443             'word   225 in the example
    ADCON1 = %00001011
    ADCON2 = %10000111
    TRISA = %00011111
    TRISB = %00000000
    TRISC = %00000111
    CMCON = 7
    PRE_CALC:                  'precalculations
      period_multiplier = 4/osc_freq
    UPDATE_SMPS:
    'take Vss reading
          temp=0
          ADCIN 0, temp
    'convert to voltage
          t_rise=L_Ipeak / v_supply       'find rise time @ supply volts for L/Ipeak
    'calculate period
          t_period=t_rise*133/10           'dutycycle = .75period
    'calculate PR2
          final_period=SMPS_period-1              'put in byte
    'LOG TO EEPROM
       if temp > 0 then
          EE_data=(temp>>8) 'high 8 bits first address
          Write 0,EE_pointer, 10,EE_data
          Write 0,EE_pointer, 20,final_duty
          Write 0,EE_pointer, 30,final_period
          EE_pointer=1
          write 0, EE_pointer
    'set ADC
      'GPIO = 0
      'CMCON = 7
      'TRISa = 0              ' designate gpio as output
      'TRISa.1 = 1         ' pin ANS0 as input  (Supply feedback)
      'TRISa.2 = 1         ' pin ANS1 as input (HV-feedback)
      'ANSEL.ANS1=1
      'ANSEL.ANS0=1
      'ADCON0.VCFG = 0         ' Vdd as Vref
      porta.4=1 'indicator light on
      Read 0, EE_pointer
      'EE_pointer=Eeprom_read(0)
      gosub PRE_CALC
      gosub UPDATE_SMPS
    'setup PWM
      last_adjust=0
    while
          temp=0
          ADCIN 0, temp ' ADC conversion
                CCPR1L=0
                CCP1CON.5=0
                CCP1CON.4=0
                porta.5=1
                porta.4=0
                last_adjust=0
                CCPR1L=high_duty
                CCP1CON=low_duty
                porta.5=0
                porta.4=1
                last_adjust=1
    wend
    end]
    Ok, first thing, I have not set up the ADC or inputs/outputs yet, this isnt an issue at the moment. i have also not finished with the EEprom yet.
    My first question is regarding the While - Wend loop.
    If the program is stuck doing stuff in this loop it cant respond to any push button inputs to turn it on or off, or dim the brightness etc. This part of the program will have to be done at the same time as the buttons are monitored. So, do I have the buttons on an interrupt or does this loop run in the back ground somehow?
    Oct 2009
    Utah, USA
    Default Re: MikroBasic to PBP Pro: Boost mode SMPS
    I'll give this a go... even though there are definately better programmers around here than me
    With microcontrollers there is very few instances where things can "go on in the background". Acutally NONE as far as the main processor is concerned, it can only do one thing at a time. Most all PIC's include onboard peripherals like PWM channels or USART serial links, timers and counters, etc. (see the datasheet for your PIC of choice and it will list all the different functions that each pin can be set up for) these peripherals can be set up to do something in the background, like the PWM channel, where you define a given pulse width and it will continue to output that pulse at a given duration and frequency while your program continues on.
    Now, you could set up the pushbutton to be tied to an I/O pin that had "Interrupt On Change" capability, either rising edge or falling edge. Then when you pushed the button an INT would be generated and the Pic could jump to the INT handler(check out Darrell Taylors "instant interrupts" for the "best" way to impliment interrupts.
    OR you could just include a check for when the button pin changed state within the while/wend loop.
    Remember... "can only do one thing at a time" is a relative statement... ie. if you push a button and the contact is closed for 200 msec's then that gives the processor a LOT of time the do something else and still get around to seeing that you are pushing a button.
    good luck!
    Dwight
    Feb 2004
    Michigan, USA
    Hi Heckler,
    Yup, I am aware things are done one at a time. I was wondering if timer based pwm could run whilst an interrupt on change was being checked for.
    I am looking at DT's instant interrupts right now actually
    Feb 2004
    Michigan, USA
    The code below will flash the LED but not create a pwm output. I'm guessing its because there are fractions and not integers to work with thus creating 0's and other odd results.
    The convert to voltage portion works fine - I changed it, but the rest needs work still.
           temp=0      ADCIN 0, temp
          'write 40, temp
    'convert to voltage
        'v_supply=v_feedback/1024
          v_supply = 1024/v_feedback * 10                            'find supply % of vref
        'v_supply=v_supply*supply_multiplier  'find supply volts
          v_supply = v_supply * supply_multiplier / 10
          write 60, v_supply
        ' = 68/24 = 2.833uS (example = 24vin)
                                           '2.833*48 = 136
    'calculate period
          t_period=t_rise*133/100                                         'dutycycle = .75period
        '2.833*133/100 =  3.767uS
    'calculate PR2
        '3.767/(4/48) = 45.2
        ' = 44.2
    CCPR1L=high_duty       'flash LED to show alive
    CCP1CON=low_duty
    portc.0 = 1
    portc.0 = 0
    GOTO main
    I see an error on your PBP program
    should be
    DEFINE OSC 48
    temp VAR word
    though I had no time to check all of your code.
    Feb 2004
    Michigan, USA
    Oops - thats a copy/paste error!!
    Basically, I need help setting up a CCP for PWM operation - I have never done it.
    Searching for examples...
    This is for 16F1827 chip I use:
      CCP1CON = %00111100          'Control of CCPx modules
      CCP2CON = %00000000
      CCP3CON = %00000000
      CCP4CON = %00000000
      CM1CON0.7=0
      CM2CON0.7=0
      CPSCON0 = 0
      CPSCON1 = 0
      DEFINE CCP1_REG PORTB
      DEFINE CCP1_BIT 3
      ccptmrs=0
      pr2=249
      ccp1con=$0C
      t2con=%00000110
    DACCON0 = 0
    HTH,
    Feb 2004
    Michigan, USA
    I didnt know you needed to add defines. I assume CCP1_BIT 3 = PORTB.3 in your example?
    Is DACC0N0 = 0 the same command as CMCON = 7? (turn off all comparators) or is it turn off all ADC's?
    Feb 2004
    Michigan, USA
    Ok, I understand everything up until this:
    ccp1con=$0C
    The pwm is already turned on as per the CCP1CON line.
    Feb 2004
    Michigan, USA
    Frustrated. Not sure what I am missing now. The CCP1 pin is always high, LED flashes correctly.
    DEFINE OSC 48
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    DEFINE CCP1_REG PORTC
    DEFINE CCP1_BIT 2
    final_duty var byte
    high_duty var byte
    low_duty var byte
    ADCON1 = 00001011
    ADCON2 = 00000011
    TRISA = 00001111
    TRISB = 01110000
    TRISC = 00000000
    CMCON = 7
    CCP1CON = 00111100
    PR2 = 44
    CCPR1L=high_duty
    CCP1CON = $0C
    T2CON = 4
    PORTC.0 = 1
    PORTC.0 = 0
    Pause 500
    Feb 2004
    Michigan, USA
    Figured it out. Helps to have a value for final_duty to load!
    final_duty = 136
    This gives me exactly what my calculations showed. 3.76uS at 75% duty cycle. 265.90KHz
    Splendid!!
    Sorry I was not online earlier. Which PIC are you using?
    Feb 2004
    Michigan, USA
    I am using a 18F2550.
    I seem to have it working at the moment however it is not very smooth.
    When the on/off button is pressed I need to sweep from 0% duty cycle up to the set limit in 1 second. I can see this happening by writing the incremental counter results to EEPROM and reading them later, however, the duty cycle does not increase for every +1 increase of the duty cycle byte. I assume this is a resolution issue due to running at 48MHz?
    I really need to smooth that out and give a very nice gradual increase in light over time.
    Also, what is a good way to have the program wait for a pin to go high?
    Currently I am using:
    waitforon:
    If PORTB.7 = 1 then 'on/off button pulled high = on
    gosub rampup 'increments final_duty and outputs value to CCP1
    PORTC.0 = 1 'flash heartbeat LED
    PORTC.0 = 0
    If final_duty = limit then 'if returned to waitforon from rampup, then final_duty is at set limit, so move on to main program
    goto waitforon
    Sometimes this will not move to rampup: or move on to main: but the heartbeat LED will always flash correctly.
    Feb 2004
    Michigan, USA
    This is the rampup subroutine.
    rampup:
    For final_duty = 1 to limit
    delay = 1000 / limit
    pause delay
    CCP1CON = %00111100
    PR2 = 44
    CCPR1L=high_duty
    CCP1CON = $0C
    T2CON = 4
    Next final_duty
    Feb 2004
    Michigan, USA
    Alright, last question of the day, I promise!
    This is the main loop code. It works fine holding the current limit by pulse skipping. The current limit is set by comparing the ADC reading to a value stored in fb, 205 in this case, or about 175mA for this application.
    The problem comes when the down button is pressed. Instead of lowering fb by 1 it goes to 100% duty cycle, and my current goes as high as the current limit is set on my bench power supply and I have to yank the power.
    I thought by lowering, or raising the value in fb, I would be able to control the current limit? What is going on?
    If PORTB.6 = 1 then
    fb = fb - 1
    If fb => 205 then
    fb = fb
    adcin 1, temp
    If temp > fb then
    final_duty = final_duty - 1
    IF final_duty = 0 then
    If temp < fb Then
    final_duty = final_duty + 1
    If final_duty = 44 then
    CCP1CON = %00111100
    PR2 = 44
    CCPR1L=high_duty
    CCP1CON = $0C
    T2CON = 4
    I don't see where you write to the EEPROM. If you do, maybe the timing for EEPROM storing (~10 msec) is creating the problem.
    Other than that it looks OK the ramp up.
    Feb 2004
    Michigan, USA
    I used it once for logging and removed it. I did compensate for the write period. I actually slowed it down a lot so I could see what was happening at individual increments.
    I tried i = fb and incrementing the i byte and not the fb byte and it works. I get a smooth up and down output now. It will current limit at each brightness setting.
    So, there is the last problem to resolve:
    When ramping up I am using duty cycle to increase brightness from zero to full on regardless of where the current limit is set at. The problems are that when I save the new current limit during the main loop, I get flashing as the output goes off during the write command and the pause 10 after the write command. Therefore, I can either write to EEPROM and ramp up to the newly set current limit, or have no flashing and ramp up to full output, go to the main loop and drop straight back to the new current limit. Both options dont look very good.
    I am not sure how to write to EEPROM and stop it from flashing.
    Aug 2010
    Maryland, USA
    I think you may need some logic in there to check for button release. As it looks now, it will run the fb = fb - 1 VERY fast, and every time through the loop when you press the button. Chances are you will not release the button before lots of main loop runs.
    -Bert
    Feb 2004
    Michigan, USA
    That is very true. I added a pause of 50mS in each button press if-endif routine.
    The problem with that is the LED's flicker each time the button is pressed. Not sure why the pause should effect the PWM. I thought that the PWM was continuous unless you turned it off with CCP1CON = 0. That was my basic understanding anyway and the theory behind the idea. Run pwm continuously and vary the duty cycle based on a target current limit and the actual feedback results. Add or subtract by one the duty cycle number until the current limit is achieved.
    Also the LED's flicker when ever there is a WRITE command so I created a counter that only writes the value every 25000 cycles.
    Even with 25000 cycles EEPROM will wear out relative soon.
    About the button,maybe you can try to wait for the button release before proceed.
    Also the the idea of add or subtract one to the duty cycle in theory it will work, practically will have a lot of jitter. Here PID control may help (more complicate though).
    Feb 2004
    Michigan, USA
    I'd be willing to learn about PID's. It's something I wanted to do anyway. Have you worked with them Ioannis?
    For something similar to what you try, but not succesfully. It just oscilated and could not fix it.
    I will try again, but am busy right now.
    Feb 2004
    Michigan, USA
    After some tweaking I have this pretty much working now. I can get it to ramp up slowly to full brightness, maintain a set level, be adjusted up and down, have the new value write to EEPROM and next time it is powered up it will ramp up to the last saved level. All I want to add now is ramp down at power off. Not a problem.
    I'd like to reduce code size though. I have a lot of IF THEN's and a lot of FOR NEXT's. They are used to increment and decrement a byte value based on which level output is set.
     rampup:l = 0
    for l = 0 to led
    if L = 0 then
    fb = 0
    CCP1CON = 0
    ramp = 0
    portc.2 = 0
    IF L = 1 then
    fb = 10
    if L = 2 then
    fb = 45
    if L = 3 then
    pause 25
    fb = 90
    if L = 4 then
    pause 40
    fb = 130
    IF L = 5 then
    pause 50
    fb = 170
    if L = 6 then
    pause 75
    fb = 280
    if L = 7 then
    fb = 450
    adcin 1, temp
    If temp > fb and L > 0 then
    ramp = ramp - 1
    IF ramp <= 0 then
    CCP1CON = 0
    ramp = 0
    portc.2 = 0
    If temp < fb Then
    ramp = ramp + 1
    If ramp >= 40 then
    ramp = 40
    If ramp > 41 then
    ramp = 0
    CCP1CON = 111100
    PR2 = 44
    high_duty=(ramp>>2)        'high 6 bits in CCPR1L
          low_duty=(ramp<<6)         'low two bits for CCP1CON
    CCPR1L=high_duty
    CCP1CON = $0C
    T2CON = 4
    next l
    This is the ramp up routine that seems to work well. The ramp down is similar. Any way to reduce this block of code in size?
    Oct 2011
    I like you project but im new user icanot able to post prease can you give instruction how can i communicate with different people in this chart
    Feb 2008
    Michigan, USA
    Can I ask for the link to the original project on Instructables?
    Feb 2004
    Michigan, USA
    Sorry, I downloaded the zip with all the files in it, so I dont have a link. I'm sure you could search for it on their site though.
    Incidentally, I got this boost controller to work and have been adding features to it. It works quite well but I still need to clean up some noise on the output.
    Feb 2008
    Michigan, USA
    A search revealed a number of them. I was just trying to narrow down which circuit you were dealing with.
    Bo
    Oct 2011
    Im a new use in this forum my project concerned about generation of 3 phase SPWM I have not know how to comunicate with different user in this link
    Quote Originally Posted by sangaboy View Post
    Im a new use in this forum my project concerned about generation of 3 phase SPWM I have not know how to communicate with different user in this link
    If you have questions, ask them in open forum, create your own thread, and people most likely will help. PM messages from strangers are usually unwelcome, and the same person who might help you in your thread may be UNWILLING if you PM them. Additionally your questions and the answers posted in a thread may well help someone else who is having a similar problem. I myself have learned many things working on someone else's problems.
