This may be a completely retarded question but i have very little experience with picbasic and picaxe for that matter.
I'm working on a project and i've got a code i've written in picaxe. I've used the readtemp command but i'm unsure how i would use this in the picbasic logic.
Is there an equivalent term to use, my programming is pretty much just comparing two temperature sources (both DS18S20's) and checking for a varience between the two, then turning on an output when the difference is great enough.
Thanks in advance
