Putting values into an array
Results 1 to 5 of 5
    Vince's Avatar
    Vince Guest
    Default Putting values into an array
    Hi!
    I'm having trouble manually placing values into an array. I'm using a 16F628 and Pic Basic Pro. Here is what I'm trying to do:
    CLAR VAR BYTE[32]
    I want to put this:
    0,1,0,1,1,1,1,0,1,1,1,1,1,0,0,1,1,1,1,0,1,1,1,1,0, 0,0,1,0,0,0,0,0
    Into the CLAR array.
    Right now, I'm trying:
    CLAR = 0,1,0,1,1,1,1,0,1,1,1,1,1,0,0,1,1,1,1,0,1,1,1,1,0, 0,0,1,0,0,0,0,0
    But it won't work. I've tried to search through this forum, but I couldn't find any solutions to this. I thought about making a FOR loop and putting each individual value in each location of the array.
    Thanks for your help!!!
    Hi Vince,
    There's probably a dozen different ways to do this. Here's 1 of them.
    Ignore this... See second post below
    For x = 0 to 31
       Lookup x,[0,1,0,1,1,1,1,0,1,1,1,1,1,0,0,1 ,1,1,1,0,1,1,1,1,0,0,0,1,0,0,0,0], CLAR[x]
    Next x
    Also, the original example has 1 too many numbers for a 32 byte array.
    HTH,
    Darrel Taylor
    Lightbulb Make it a bit array
    Hello Vince,
    If all you are loading is 1's and 0's, why don't you make it a bit array?
    Use the method that Darrel suggested, but declare "CLAR" as a bit type array.
    For example...
    CLAR VAR BIT[32]
    I hope that Darrel's suggestion can be implemented using a bit variable. I haven't used the "Lookup" command yet, so I'm not sure. However, If you can then the "CLAR" array will take up 8 times less memory than if you declare it as a byte array.
    Good luck.
    picnaut
    ---> picnaut
    Vince
    Well, after trying to compile my previous example, I found that IT DOESN'T WORK!
    Not to worry, only one minor problem. The lookup statement doesn't seem to like having an array variable as the output.
    Using a Temp variable then copying it to the array seems to work fine. So now it should look like this.
    CLAR VAR BYTE[32]
    x    VAR Byte
    Temp VAR Byte
    For x = 0 to 31
       Lookup x,[0,1,0,1,1,1,1,0,1,1,1,1,1,0,0,1 ,1,1,1,0,1,1,1,1,0,0,0,1,0,0,0,0], Temp
       CLAR(x) = Temp
    Next x
    Also,
    picnaut has a good point about the bit arrays, and yes, the revised version will work with them. (I checked before saying that)
    HTH,
      Darrel Taylor
    Vince's Avatar
    Vince Guest
    Talking
    Thank you guys so much for the help!!! ^_^ I will implement this code and see how it works. Thanks again!!!
    Last Post: - 14th June 2016, 07:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  3. Array values changing
    By MyBuddy in forum mel PIC BASIC Pro
    Last Post: - 29th October 2009, 23:13
  4. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 08:02
  5. Reading Array values into variables
    Last Post: - 21st March 2005, 10:30
