Debug speed question
Results 1 to 3 of 3
    Default Debug speed question
    Okay, I think this is a simple question. Can someone help fill in the blanks.....
    How long does it take to print 58 characters using debug at 9600 baud with a 12F1822 running at 8 mhz? The receiving device is Hyperterminal.
    I think the calculation goes something like this:
    10 bits per character (1 start,8 data,1 stop}
    58*10/9600 = .060 seconds
    Debug processing time = ?
    Hyperterminal processing time = ?
    Aug 2008
    Portugal
    Default Re: Debug speed question
    I would like this;
    Start a timer
    Debug command
    Stop the timer
    Read the Timer registers and do the Math.
    On the hyperterminal side, don't know, but if you do a VB program to receive the data you can control that too.
    Thanks and Regards;
    Gadelhas
    Sep 2005
    Campbell, CA
    Hyperterminal can handle the chars as fast as they come - at least up to 115K baud.
    Debug is really a lot better than I thought. Unfortunately, I don't have a 12F running at 8Mhz. All I have is an 18F8723 running at 40Mhz.Name:  DEBUG.jpg
    I sent out $FF in a loop. Note that there is virtually no extra space between ANY of the bits. So DEBUG is very fast. But remember that DEBUG is a blocking command. If all you have to do is pull bytes out of an array and send them, you will see the same results I do, but if you have to calculate or use some logic between sending bytes, that will add a bit of time.
    Charles Linquist
