9 times out of 10, my program awakes fine (IOC interrupt related), but....
Results 1 to 11 of 11
Threaded View
  1. #4
    Mar 2009
    Default Re: 9 times out of 10, my program awakes fine (IOC interrupt related), but....
    Thanks bert :-)
    Ok, I've removed all the gosubs from the interrupt routine, but I'm still getting erratic results...I kinda know what's not causing my PIC to go to sleep , but the workaround is ugly.
    I think I'm hitting diffs with nested gosubs. Imagine this scenario (this is just high evel *not* my actual code - just to get my problem across)...
    loop1:
    if pattern = 2 then goto loop2
    IF sleep_flag = 1 THEN GOTO SLEEP_ROUTINE
    pause 10
    gosub decrease duty
    gosub select_LED1
    pause 10
    gosub increase_duty
    goto loop1:
    loop2:
    if pattern = 1 then goto loop1
    pause 10
    gosub decrease duty
    gosub select_LED2
    pause 10
    gosub increase_duty
    goto loop2
    SLEEP_ROUTINE:
    debug "PIC off to sleep",13,10
    pause 200
    @sleep
    ' program continues here afteran IOC interrupt....
    debug "PIC awake",13,10
    IOC_Int:
    @ INT_DISABLE  IOC_INT
    if sleep_flag = 1 then ' if we wake from asleep, this flag will be set still need to clear it & retun to the main program
    sleep_flag = 0
    goto INTERRUPT_END
    LOOP3:
            IF SW1 = 0 THEN
            COUNT3 = COUNT3+1
            IF COUNT3 >300 THEN      'if Sw1 held for 300mS then set sleep_flag
            SLEEP_FLAG =1
            goto INTERRUPT_END
            pause 1
            GOTO LOOP3
    if pattern <2 then    pattern=pattern+1  'cycle between pattern1 & pattern 2
    pattern=1
    INTERRUPT_END:
    COUNT3 =0
    while sw1=0
    wend
    PAUSE 180
    IOCAF = 0         'CLEAR THE INTERRUPT FLAG
    @ INT_ENABLE  IOC_INT
    @ INT_RETURN
    It seems the interrupt routine (or program!) doesn't like the highlighted Gosubs in the loop1 & loop2 - if I remove the gosubs & instead locate the actual code contents of the gosubs in each loop - then everything is dandy (i.e. the PIC always goes to sleep & awakes fine) , but if I have gosubs in those two main loops - it looks like the interrupt routine (or some other aspect of my program) doesn't return to the main two loops & then trap the sleep_flag being hit! (the problem here is that by not using gosubs I run out of program space *very* quickly!)
    What am I missing here?
