I might be doing it wrong, but with VCC being 3 volts I have not had any problems.I thought I would have to also put one on the leg of the backup battery supply so that when Vcc is active, that diode protects the backup battery from the Vcc voltage.
Correct, I had a part that got pushed to the back of the bench for around six months (no external power) and the RTC was still alive when I fired it up.evidently it will keep on trucking when Vcc is shut down. Correct??
Yes, I am looking at it.can you take a look at my EMAIL routine
