Vss and Vdd pins are not necessary or can be omitted?
No, I am saying that it can.
Say you have a MCU with an I/O sourced to different power supplies. If the I/O is high and the power is cut to the MCU the MCU will not be able to reset. The voltage on the I/O will keep the MCU running or in a near run state. The I/O can even be a RS232 input.
For a test, have the MCU keep a LED high (lighted), apply 5 volts to an input. Turn the power off to the MCU while keeping the input at 5 volts. Look at the LED.
