Soldering station
Results 1 to 38 of 38
    Dec 2008
    Ploiesti, ROMANIA
    Default Soldering station
    Using Pensol SL10, one cheap 12F675 and N3310 display, I made for myself this soldering station. Works fine, the mos-fet remains cool, but... I wonder if my code it's the better way to drive the mos-fet and keep most accurate temperature of iron ("pwm mosfet, 255, 300").
    Any advice it's wellcome ! Thanks in advance !
    '*                   Statie digitala de lipit, cu display de NOKIA 3310        *
    '*                 Digital solering station with N3310 display            *
    '*                           by Dan Niculescu, june 2011                        *
    @ DEVICE PIC12F675, intrc_osc_noclkout, wdt_off, mclr_off
    DEFINE OSC  4
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    CMCON    = 7
    TRISIO   = %001001
    INTCON   = 0
    GPIO     = 0
    ANSEL    = %00010001
    ADCON0   = %10000001
    wpu      = %00000010
                D_C      var     GPIO.2
                SDIN     var     GPIO.4
                SCK      var     GPIO.5
                MOSFET   var     GPIO.1
              buton    var     GPIO.3
                LcdReg          var  byte
                x               var  byte
                y               var  byte
                z               var  byte
                a               var  byte
                PosX            var  byte
                PosY            var  byte
                Chr             var  byte
                LcdData         var  byte
                Offset          var  byte
                Char            var  byte
                adval           var  word
                w1              var  word
              vt              var  word
              cnt             var  byte
                grup            var  word
                mode               var  byte
              calibra         var  word
                i               var  byte
                DATA @0,$3E,$51,$49,$45,$3E,_       ' 0
                        $00,$42,$7F,$40,$00,_       ' 1
                        $42,$61,$51,$49,$46,_       ' 2
                        $21,$41,$45,$4B,$31,_       ' 3
                        $18,$14,$12,$7F,$10,_       ' 4
                        $27,$45,$45,$45,$39,_       ' 5
                        $3C,$4A,$49,$49,$30,_       ' 6
                        $01,$71,$09,$05,$03,_       ' 7
                        $36,$49,$49,$49,$36,_       ' 8
                        $06,$49,$49,$29,$1E,_       ' 9
                        $08,$08,$3E,$08,$08,_       ' +
                        $08,$08,$08,$08,$08,_       ' -
                        $00,$60,$60,$00,$00,_       ' .
                        $00,$02,$05,$02,$00,_       ' grad
                        $3E,$41,$41,$41,$22,_       ' C
                        $7F,$02,$0C,$02,$7F,_       ' M
                        $00,$00,$00,$00,$00,_       ' space
                     $08,$04,$7F,$04,$08,_       ' arrow up
                        $20,$40,$7F,$40,$20         ' arrow down
        Low D_C                                  'Command/Data
               LcdReg  =  %00100001         'LCD Extended Commands.
               call    PrintCtrlLcd
               LcdReg  =  $FF               'Set LCD Vop (Contrast).Initial $C5
               call    PrintCtrlLcd
               LcdReg  =  %00000110         'Set Temp coefficent.
               call    PrintCtrlLcd
               LcdReg  =  %00010011         'LCD bias mode 1:48.
               call    PrintCtrlLcd
               LcdReg  =  %00100000         'LCD Standard Commands
               call    PrintCtrlLcd
               LcdReg  =  $0C               'LCD in normal mode.  $0D inverse
               call    PrintCtrlLcd
    Pause 100
    Call CursorHome
    Pause 100
    Gosub LCD_Clear
    mode = 0
    Pause 500                ' time to give-up :)
    '===================== READING VOLTAGE ==============================
    low mosfet
    call Borderline
    pause 50
     vt=0
     grup=0
         for cnt = 1 to 20
     ADCON0.1 = 1
     WHILE ADCON0.1 = 1 : WEND
     Pause 10
     adval.HighByte = ADRESH
     adval.LowByte = ADRESL
     PAUSE 10
         vt=adval * 500
         vt=div32 1023
         grup=vt+grup
     PAUSE 10
         next cnt
     w1=grup / 20
    '===================== setting cursor for display the voltage
                    LcdReg  =  %10000000 + 25        ' cursor  X
                    call    PrintCtrlLcd
                    LcdReg  =  %01000011             ' cursor  Y
                    call    PrintCtrlLcd
    '===================== now display results
     if (w1 dig 2) <1 then
                    char = 16
                    call Printchar
                    Char = (w1 dig 2)
                    call    PrintChar
                    Char = (w1 dig 1)
                    call    PrintChar
     if (w1 dig 0) < 5 then
                    Char = 0
                    call    PrintChar
                    char = 5
                    call PrintChar
                    Char = 16
                    call    PrintChar
                    Char = 13
                    call  PrintChar
                    Char = 14
                    call  PrintChar
    if buton = 0 then
    mode = mode + 1
    gosub memo
    gosub check
    Pause 100
    Goto Main
    '================== L C D ===========================================
    CursorHome:     LcdReg  =  %10000000            ' cursor Home
                    call    PrintCtrlLcd
                    LcdReg  =  %01000000            ' cursor Home
                    call    PrintCtrlLcd
    PrintChar:      offset = Char * 5
                    for a = 1 to 5
                        read offset, LcdReg
                        call  PrintDataLcd
                        offset = offset + 1
                    next a
                    LcdReg = 0
                    call    PrintDataLcd
    PrintCtrlLcd:   D_C = 0
    PrintDataLcd:   for x = 1 to 8
                        SDIN = LcdReg.7
                        SCK = 1
                        LcdReg = LcdReg << 1
                        SCK = 0
                    next x
                    D_C = 1
    LCD_Clear:
                    PosX=0:PosY=0:Gosub LCD_GotoXY
                    D_C = 1
                    FOR Chr=1 TO 252
                        LcdData=0:Gosub LCD_ByteOut
                    next Chr
    LCD_GotoXY:
                    D_C = 0
                    LcdData=%01000000 | PosY :Gosub LCD_ByteOut
                    LcdData=%10000000 | PosX :Gosub LCD_ByteOut
    LCD_ByteOut:
                    SHIFTOUT SDIN,SCK,1,[LcdData]
    GotoXY:
    LcdReg = %01000000 | Posy : call    PrintCtrlLcd    'Y
    LcdReg = %10000000 | Posx : call    PrintCtrlLcd    'X
    memo:
    if mode = 1 then
     gosub poz
     char = 17
     call    PrintChar
     calibra = 4800
    if mode = 2 then
     gosub poz
     char = 15
     call    PrintChar
     calibra = vt
    if mode = 3 then
     gosub poz
     char = 18
     call printchar
     calibra = 10
    if mode > 3 then
      mode = 0
     gosub poz
     char = 16
     call printchar
    check:
    if mode >= 1 then
        if w1 < (calibra-2) then  pwm mosfet, 255, 300
        low mosfet
    Poz:
                    LcdReg  =  %10000000 + 67        ' cursor  X
                    call    PrintCtrlLcd
                    call    PrintCtrlLcd
    BorderLine:
    '=================================== RAW UP
          LcdReg  =  %10000000            ' cursor  X
          call    PrintCtrlLcd
          LcdReg  =  %01000000            ' cursor  Y
          call    PrintCtrlLcd
          for y = 0 to 83
          LOokup y, [$FF,$01,$01,$01,$01,_
                     $01,$01,$01,$01,$01,$01,$01,$01,$01,$FD,$FD,$FD,$85,$85,$FD,$FD,$79,_        'D
                     $01,$01,$FD,$FD,$FD,$01,$01,$79,$FD,$FD,$85,$A5,$ED,$ED,$69,$01,$01,_        'IG
                     $FD,$FD,$FD,$01,$05,$05,$05,$FD,$FD,$FD,$05,$05,$05,$01,_                    'IT
                     $F9,$FD,$FD,$25,$25,$FD,$FD,$F9,$01,$01,$FD,$FD,$FD,$81,$81,$81,$81,_        'AL
                     $01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$FF] ,LcdReg
          call    PrintDataLcd
          next y
    '===================================  RAW 1 to 4
    for i= 1 to 4
    posx=0
    posy=i
    gosub GotoXY
                   lcdReg= $FF
                   call    PrintDataLcd
    next i
    for i = 1 to 4
    posx=83
    posy=i
    gosub GotoXY
                   lcdReg= $FF
                   call    PrintDataLcd
    next i
    '===================================  RAW DOWN
          LcdReg  =  %10000000
          call    PrintCtrlLcd
          LcdReg  =  %01000101
          call    PrintCtrlLcd
          for y = 0 to 83
          LOokup y, [$FF,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
                   $80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
                   $80,$80,$80,$80,$80,$80,$80,$80,$FF] ,LcdReg
          call    PrintDataLcd
          next y
    End             'of program
    Default Re: Soldering station
    Hi Fratello,
    You REALLY like those Nokia graphic LCD . . .
    I think they're pretty cool too, Now as for USEFUL comments . . . According to the engineer from France who writes the Dark Side column in Circuit Cellar, . . Robert La Coste ? his suggestion is to use a PID loop to give you some Hysteresis to your temperature to prevent overshoot and undershoot of tip temp. Search the forum there is a pretty good one or more in circulation.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for advice !
    I found this : incPID_mc.pbp Author : Henrik Olsson. GREAT WORK !
    Unfortunately the code don't fit in my small 12F675 ; it's a solution to upgrade to a bigger PIC (18F2550 ?) but... for my small device it's another way ?!
    ...and yes, I like this display : it's verry cheap (about 1 euro) and easy to use. One 2x16 LCD display it's 6 euro and don't look so nice .
    Bombay, India
    I can assume you're almost at the limits of the code space with your current code. The best option, I reckon, to get reasonably good control with your existing setup would be to try PI control. As it is, you are using the PWM function. Just compute the proportional output to get a smoother control.
    Modify your check routine so that the PWM function outputs 255 when far lower than the setpoint, 0 when at it. Now, to compensate the offset of the temperature, you add the integral correction over time. This can be achieved quite easily with integer math alone.
    A typical P controller pseudo code
    Band con 10 ' this decides the band around SetPoint in which you want proportional control
    if Temp < SetPoint-Band then
    PWMout = 255 ' full heat
    if Temp > Setpoint+Band then
    PWMout = 0 ' full off
    ' within band, do Proportional heating
    Error = SetPoint+Band-Temp ' you want to get the bigger numbers for temp < sv
    PWMout = (Error*255)/(2*Band) ' get an output from 255 to 0 over the band from SV-Band to SV+Band, 50% at SV
    Adding integral is relatively easy too. You just need a variable to adjust the error over time. Or use a button to snapshot the error and add it as an offset.
    IntErr var byte
    IntErr = IntErr+(Error/IntTime) ' integrate the error over time
    PWMout = PWMout + IntErr
    if PWMout > 255 then PWMout = 255 ' limit to usable PWM range
    PWM Mosfet, PWMout, 300 ' transfer to the mosfet
    Just some ideas.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You so much ! I try and I post the results.
    Dec 2008
    Ploiesti, ROMANIA
    I cannot run my simulation ( AMD Athlon64 X2 DualCore 4200+, 2 GB RAM ?!) ...
    It's this code OK ? Thanks !
    hyst            CON  2
    check:
    if mode >= 1 then
        if w1 < calibra-hyst     then pwm mosfet, 255, 300
        if w1 > calibra+hyst     then low mosfet
        if w1 = calibra+hyst-w1 then pwm mosfet,(w1*255)/(2*hyst), 300
