18f26k22 - setting fuse in program
Results 1 to 8 of 8
    Default Re: 18f26k22 - setting fuse in program
    Steve, also read this...
    17.2.10 A/D CONVERSION PROCEDURE
    This is an example procedure for using the ADC toperform an Analog-to-Digital conversion:1. Configure Port:• Disable pin output driver (See TRIS register)• Configure pin as analog2. Configure the ADC module:• Select ADC conversion clock• Configure voltage reference• Select ADC input channel• Select result format• Select acquisition delay• Turn on ADC module3. Configure ADC interrupt (optional):• Clear ADC interrupt flag• Enable ADC interrupt• Enable peripheral interrupt• Enable global interrupt
    (1)
    4. Wait the required acquisition time
    (2).5. Start conversion by setting the GO/DONE bit.6. Wait for ADC conversion to complete by one ofthe following:• Polling the GO/DONE bit• Waiting for the ADC interrupt (interruptsenabled)7. Read ADC Result8. Clear the ADC interrupt flag (required if interruptis enabled).
    EN82fn
    Steve, I also don't see where you are setting the A/D reference voltage source...
    EN82fn
    Oct 2011
    Hi Dave,
    I'll test as soon as possible following your advices
    Many thanks for your help...
    Steves
